intake gasket - Defender Source
Old November 20th, 2014, 05:21 PM
wesley0620
Wesley Everett
1994 Defender 90
intake gasket
I'm currently changing a 94 D90 from ECU control to carburetor I am using an Edelbrock 2198 intake I have seen that you shouldn't use factory intake gaskets any help?
Old November 20th, 2014, 05:56 PM
I can't see any reason why you shouldn't use a factory intake gasket. I also can't see why on earth you would want to convert to a carburettor. You may as well install some leaf springs while you are at it.
Old November 20th, 2014, 06:23 PM
the rover shop
shayne young
I wanna say there was a difference in the coolant ports of the edelbrock to efi manifolds.. Just compare the 2 to see that they are the same.. I have both here and I can check the coolant routing tomorrow..
Old November 21st, 2014, 08:39 AM
wesley0620
Wesley Everett
1994 Defender 90
Bad ECU
The reason I am changing to carb is that the ECU went out and just try buying one of those
Old November 21st, 2014, 09:27 AM
I have an ECU I will give you for shipping.
Old November 21st, 2014, 09:36 AM
the rover shop
shayne young
What's the number on your existing ecu.??
Old November 21st, 2014, 07:01 PM
You can get them for under $200 used. What's wrong with your ECU?
Old November 21st, 2014, 08:03 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You will spend a lot less finding a ECU rather than buying the intake and carb.......
Old November 22nd, 2014, 08:26 PM
wesley0620
Wesley Everett
1994 Defender 90
ECU number
EER 4943 is the factory number
Old November 22nd, 2014, 08:43 PM
wesley0620
Wesley Everett
1994 Defender 90
ECU problem
Had a severe over fueling problem sent ECU to repair shop and they said ECU is pulsing injectors every time and was the problem but they didn't have parts to repair bought one online and wouldn't even crank that's when I decided for carb
------ Follow up post added November 22nd, 2014 08:52 PM ------
Bill Adams let's do it let me know how much shipping is
Old November 22nd, 2014, 10:37 PM
I doubt your ECU is the problem. Just a guess, but your coolant temperature sensor is probably bad causing it to tell the ECU that is very cold out making it run at full rich.
Old November 23rd, 2014, 02:52 AM
wesley0620
Wesley Everett
1994 Defender 90
I have already changed fuel temp sensor, idle air control,fuel pressure regulator, did an injector leak down test
------ Follow up post added November 23rd, 2014 02:55 AM ------
I changed engine coolant temp sensor first
Old November 23rd, 2014, 04:42 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Check the resistor on the mass air harness should be 6.8-7.3 ohms if remember . Often over looked and will cause you to chase your tail at times .
85 D110 3.5 3 DR
Old November 23rd, 2014, 09:40 AM
Did you do a drag test on the pins for the coolant temp sensor? Those connectors often get corroded or break. Its just a standard GM fuel injector connector. You really should consider not doing the carb setup. You should be able to fix your fuel injection issues.
Old November 23rd, 2014, 05:12 PM
lightwriter's Avatar
lightwriter
Carlos Ascencio
'84 One Ten
where?
Don't mean to hijack but where can you find an ECU for less than $200? I need a 14CUX and not had any luck.
Old November 23rd, 2014, 05:14 PM
car-part.com
gas
3.9L coolant on intake valley gasket Iamkraig Defender Technical Discussions 2 March 28th, 2014 06:55 PM
Should it cost $1000 to replace my intake manifold gasket? phoenix37 Misc. Chit-Chat 7 July 9th, 2008 07:25 AM
gasket kit 3.9 bstraw Wanted 0 February 20th, 2006 09:53 AM
replacing intake manfold gasket mattdh Defender Technical Discussions 1 May 27th, 2004 10:00 AM
