Insulation between headliner and roof - Defender Hard Top Question - Defender Source
Old May 7th, 2013, 11:04 PM
COSteve
Steven Reed
93 Defender 110 - #107
What insulation type has proven effective to install between the headliner and the roof?
I get the Dynamat approach - for sound deadening and attenuation, and it sticks and it must insulate "some"...
Has anyone done the Dynamat AND some dead air product on the roof plus the headliner recovered ?
Closed Foam, Batt "split" as I understand that there is only a thin space to work with....etc.
Thanks!
COSteve
Old May 8th, 2013, 03:02 AM
Canol109's Avatar
Canol109
Dave
1991 Defender 110
I've used a product that I got at my local lumber/hardware store. It is used for carpet underlay. Almost the same product that you put under laminate hardwood flooring.
A lot cheaper solution than Dynamat.
It definitely reduce the noise and gives some additional insulation.
It comes in large width rolls, easy to cut and form. You should be able to find this at any carpet supplier or Home Depot...as that is where I got it from.
It is totally synthetic and won't hold any water. I ended up using the "right stuff" gasket sealer as 3M spray adhesives wouldn't hold when it go hot...plus the spray inside the truck was nasty. The Sealer has worked fantastically.
I can't seem to recall the name of the product...here's a pic if that helps at all.
https://www.dropbox.com/sh/42u7abbjn2aoeh9/vxW07G3V_u
_______________________________________________
1991 x-MoD 19 KK 88 Defender 110
1965 x-MoD 35 ET 73 Sankey Narrow Track Trailer ~
1955 Series 1 86 Hardtop 173601415
1955 Series 1 86 Hardtop 57130577 ~ just a heap o' parts now
1985 Series III 109 x-MoD BATUS 77 KC 63 < sold
Old May 8th, 2013, 04:21 AM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
Reflectix .... looks like those silver bubble wrap window shades....but it is not the same.
http://www.amazon.com/Reflectix-ST16...ords=reflectix
Its a much tougher material....thicker mylar and very effective. Ultralight backpackers use it to insulate their cooking pots to save fuel.
I originally used it for the same then began to experiment.
I taped together a simple wrap for a gatorade bottle ... and it keeps it cold for hours.
Now i use it mostly as an impromptu cooler.....every flight i take from the USA to Israel, i make a pouch.....stuff it with hard to find Pork products and smuggle it into the Jewish state.
Also made a pouch for my camelbak.
I already imported 2 rolls here to Israel to line my roof, but I haven't gotten around to installing it yet.
Saving my pennies to dynamat it first. As expensive as the Dynamat is on Amazon...Its triple here.
Anyway....Refelectix is thin and cheap and extremely light weight.
It can be found and Home Depot and Lowes.
Also a ton of uses can be found on Expedition Portal forum.
Search for Reflectix.
Good Luck
Edit: Here is an example of a roof install.
http://www.flashoffroad.com/Maintena...acproblems.htm
Old May 8th, 2013, 06:44 AM
I used Second Skin Damplifier Pro for dampening, and then i applied Heat Wave Pro over that for insulation using 3M spray adhesive. That was a highly effective combo. Takes very little heat or AC to manage the 110 cabin now.
Mark Kellgren
KM4BOR
Old May 8th, 2013, 07:04 AM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
Sounds like good stuff....
If i remember correctly doesnt your truck have the LaSalle Trim fiberglass headliner installed ? If so i wonder if maybe the Lasalle has more room between it and the roof. I have never seen it in person.
Old May 8th, 2013, 07:43 AM
yep, LaSalle. I couldn't comment either as I have no idea how much room the OEM has. LaSalle gives you about an inch of space I think.
Mark Kellgren
KM4BOR
Old May 8th, 2013, 07:48 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I used Dynamat and Dynaliner (closed cell foam) on mine
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old May 8th, 2013, 09:40 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I am in a similar boat looking for insulation for my D90 roof. My research lead me to a product called 3M Thinsulate Acoustic (http://solutions.3m.com/wps/portal/3.../applications/ )
Unfortunately, this is not readily available to the public. Fortunately, there is a chap on ebay selling some :-) I just picked up a 5'x10' piece for $75 (he has more, just search 3m acoustic thinsulate) and am looking forward to receiving it. Definitely check out this product--seems inexpensive (at least through the ebay guy, comes in at $1.50/sq ft), great sound deadener, hydrophobic, and lightweight. Worth a look.
(BTW--I have absolutely nothing to do with the ebay seller)
Old July 11th, 2013, 02:02 PM
COSteve
Steven Reed
Chris, how did your Thinsulate install go?
For the forum.. so optimal would be a "dynamat" install for sound, AND the Thinsulate install for heat / cool insulation?
COSteve
Old July 11th, 2013, 02:48 PM
Darby
Darby Richards
1992 Defender 110 200TDI
I'm currently in the process of insulating my roof. I used the CLD tiles (Used in the center of each section - between the ribs of the roof), wrapped the wires with harness tape (cloth tape - to stop and ratteling) and then i'm going to install 3M insulation.
Check out http://www.sounddeadenershowdown.com...product-prices
They have some great products - I have no affiliation with this company.
Old July 11th, 2013, 03:08 PM
ezzzzzzz
Mark Garrenton
I used Second Skin extensively throughout my 240Z. The noise reduction as well as heat/cool retention inside is noteworthy. They provide an excellent product.
Old July 11th, 2013, 03:11 PM
Ray_G's Avatar
Ray_G
Ray Gerber
I'll second what Rob recommended; the Reflectix stuff from Home Depot/Lowes works well, is cheap, and easy to work with. I installed it when I re-did my headliner-made a difference both for temps but also with sound. Tough to tell how much given what I did with the headliner too but for the cost and effort it was worth it.
r-
Ray
Old July 11th, 2013, 03:14 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
COSteve
I still have not figured out my headliner so I have not installed it. My wife leaving her job has put a stop to a lot of the projects that I have planned, so the Thinsulate is still in my garage waiting on some time/$$. I would love to hear what others are doing--it will help make my learning curve shorter :-)
Old August 1st, 2013, 07:03 PM
coffee's Avatar
coffee
John Oates
1993 NAS Defender 110 #367/500
How much space do you have for both the dynamat and the dynaliner? I was planning on using dynamite extreme coupled with either 1/4" or 1/2" dynaliner, but am not sure how much space I have to work with. Should I do 1/4" dynalyner or do you think I can do 1/2" over the dynamat? thanks for your input - I appreciate it.
Whats in my container??????? SafariHP The Vendors Loft 30 November 26th, 2015 07:31 AM
110 hard top BOBCAT110 For Sale - Parts 9 October 11th, 2011 04:36 PM
Fiberglass Hard Top chris snell For Sale - Parts 7 August 2nd, 2010 11:45 AM
D90 Hard Top and Sides Ren Ching For Sale - Parts 9 March 20th, 2009 05:50 PM
D90 Station wagon hard top for sale k4rovers For Sale - Parts 0 January 31st, 2005 10:46 AM
