Instrument Cluster - Defender Source
Old April 13th, 2012, 06:26 PM
Defender_90
Kevin Doonan
1999 RR HSE
Instrument Cluster
I just tried taking my instrument cluster out to try and solve the 100k issue using the links that others posted on my earlier post, but i am not able to get the instrument cluster out far enough to let me try and resolve the issue.
It appears that the cable from the speedo to the transmission is just not giving me enough slack and though I freed up as much as possible in the engine compartment, I am still not able to get enough slack/room to begin to take the speedo out of the cluster.
Any advice on this?
KD
Old April 14th, 2012, 10:04 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
If you grab the cable where it goes into the back of the speedo head, you'll feel a couple of lugs... squeeze them together and it'll pop off, you can then pull the instrument cluster right out (as far as the wires will let you)
to replace it, line up the inner "cable" into the lug on the back of the speedo, then just push it up in... should click and lock into place.
Anyone Ever fitted a RH drive instrument cluster to a LH dash? LRNAD90 Defender Technical Discussions 3 September 23rd, 2008 03:22 PM
SW Instrument Cluster Excellent Condition SafariHP The Vendors Loft 0 May 3rd, 2008 08:34 PM
Instrument Panel Cluster Replacement JMPDIV82 Defender Technical Discussions 11 October 28th, 2007 04:05 PM
steering wheel and instrument cluster needed ember Wanted 4 May 9th, 2007 02:34 PM
defender instrument cluster needed ember Wanted 0 February 26th, 2004 02:01 AM
