installing Warn XD9000i winch in ARB bumper - Defender Source
Old March 27th, 2006, 07:14 PM
eric_besore
Eric Besore
I did some searching in the forums and found a couple of threads on installing an XD9000i in an ARB bumper, and what I read was that you could either:
a) install the winch on it's "back" so that the feet are mounted through the roller fairlead requiring putting new mounting holes in the roller fairlead.
b) position it upright, but cut the top of the ARB bumper.
I would really rather mount it upright. So my question is has anyone did b) and how did it turn out? From looking at pics of the bumper it looks like you could cut away the top a little bit and the winch would just stand up through it. Doing some research on Warn's website it looks like the dimensions and mounting bolt pattern are identical between the xd9000 and xd9000i except for xd9000 have the remote control pack so it being a lilttle bit shorter.
So has anyone mounted the xd9000i upright in the ARB after modifying the ARB, and if so do you have pics or suggestions?
My new ARB bumper arrives this weekend, already have the xd9000i.
Any help is appreciated.
Eric Besore
Old March 27th, 2006, 09:19 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I bought a 24" long Ramsey winch tray from Summit Racing and trimmed the two front corners with a Sawzall to match the "tapers" of the inside of the ARB bumper (make a cardboard template). The winch will mount upright on the tray. I used a couple of short pieces of angle iron 1-1/2" x 1-1/2" x 2" long to make brackets to support the back corners of the tray - the front will bolt up to existing holes in the bumper. You might have to slightly enlarge the cutout in the right (passenger side) of the bumper support bracket where the winch motor efits into the notch. If I had been just a touch more careful on my measurements I may have avoided that step.
This setup works real well - the diode bridge is about even with the top of the bumper where the light mounting tabs are - doesn't obstruct the radiator at all. The winch tray is predrilled for the bolt pattern of the winch and there is plenty of clearance between the back of the winch and the grill.
This also helps stiffen up the ARB bumper and the "floor" provided by the winch tray helps keep gunk out of the winch line.
Old March 27th, 2006, 11:54 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
I've got the same equipment. I believe the 'lying on its back' position to be stronger as the forces are directed down through the feet instead of at a tangent to direction of pull. Drilling two holes in the fairlead isn't that tough. Why do you want it upright?
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old March 28th, 2006, 12:06 AM
eric_besore
Eric Besore
why...?
I was thinking that mounting it upright might be the best way to go since that is how the winch was designed. Also I have heard that if you mount it on it's back, that water can collect in the control housing top portion - just what I have read, don't know if that is true or not.
Eric Besore
Old March 28th, 2006, 08:33 AM
I think Art and Jimmy both have mounted there's upright. I know Jimmy just had a 1/2" steel plate welded in between the frame rails, then drilled a few holes in it and bolted it up! Works fine!
Old March 28th, 2006, 11:50 AM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
I haven't run into that problem. Of course, we don't do a lot of river fording down in Texas so I can't really comment. We do get some very heavy rains, like right now though, and everything seems to work fine afterwards.
Old March 28th, 2006, 12:03 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I had mine "lying on its back" in the ARB on my Range Rover - it was always a pain plugging in the control lead so I decided to mount it upright in the D-90. I had also heard that the drain holes in the housing for the solenoid pack were in a location where the winch was supposed to be upright. I'll get a picture and post it this evening.
Old March 28th, 2006, 12:14 PM
eric_besore
Eric Besore
Awesome, a photo would really help me out. I appreciated it Jack.
Eric Besore
Old March 28th, 2006, 05:54 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Here are some pics of my winch installation -
Pic # 1 shows the way the winch tucks in below the horizontal bar.
Pics #2 & 3 look down at the top of the Ramsey winch tray.
Pics #4 & 5 look up from the bottom and shows the winch tray and the angle iron mounting tabs that support the back corners. If you look closely at Pic 5 you can see where I had to trim the front corners of the winch tray to match the angled front of the ARB bumper.
ID:	5287   Click image for larger version
ID:	5289   Click image for larger version
Old March 28th, 2006, 06:43 PM
eric_besore
Eric Besore
Jack, so did you cut the top of the ARB bumper then so that the XD9000i is poking through it?
Old March 28th, 2006, 07:18 PM
Jase
Jase
pending
Mounting it upright or back down will not effect operation. I had an xi mounted back down in an ARB on a FJ80 for a number of years. The 80 was my DD and saw a lot of rain and snow and I never had a problem with water collecting in the soleniod pack.
Old March 28th, 2006, 09:36 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I didn't have to cut the ARB at all except for some slight enlargement of the motor notch in the passenger side "frame" rail - no top on mine.
90, arb bumper, bumper, d90, winch
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
ARB winch bumper naeirie Defender Technical Discussions 1 July 9th, 2005 01:53 AM
D90 ARB front bumper w/ winch mount taoseno For Sale - Parts 17 October 14th, 2004 11:32 AM
D90 ARB front bumper w/ winch mount taoseno For Sale - Parts 0 August 10th, 2004 01:41 PM
Warn XD9000i in ARB brush bar... Trigger Defender Technical Discussions 2 June 15th, 2004 12:26 AM
