installing the diamond plate wing top protectors - Defender Source
Old May 23rd, 2012, 09:38 PM
pdella
Paul
1997, Defender Alpine White
Any advice on installing the diamond plate wing top protectors that I purchased from Rovers north? Someone suggested not using the attached screws and using a special type of rivet that you can use a SSteel to screw into so you may remove it later as well as applying a bead of silicon around the edge
Old May 23rd, 2012, 09:47 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I just did this over the weekend. No need for fancy rivnuts. I just use stainless steel hardware and locknuts on mine. You can easily reach under the wing to get at each bolt. Some protectors have a rubber liner that goes under the treadplate. I didn't use any liner or silicone. What's the point? It a Defender. Get it dirty
MUDSUX
Old May 23rd, 2012, 10:29 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Some people feel that adding silicon will actually trap moisture and create more of a problem. I too used the hardware that came with mine and no silicon.
Land Rover 110
Old May 23rd, 2012, 10:35 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
The wing protectors from RN comes with a neoprene mat. Follow the instructions and use the hardware provided.
Old May 24th, 2012, 01:18 AM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Probably not a big deal, but since the wings are aluminum and the chequer plate is aluminum I have aluminum rivets holding mine on.
Old June 3rd, 2012, 10:35 PM
pdella
Paul
installing wing protector plates
I bought wing protectors from rovers north and they didn't come with instructions or a mat? I looked into installing them today and the screws for the black vents don't reach the screw anchors clips on the hood when they sit on top of the checker pieces. How did you easily screw in the bolts- it looks like I have to remove the evaporator canisters and other stuff to get to the nuts in the outside front corners.- Is it because I have a 97?
Old June 4th, 2012, 04:51 AM
You can get ugly galvanic corrosion if the stainless screw grinds off any of the anodizing on the aluminum. A mylar washer will go a long way towards helping prevent that. I prefer sinking aluminum rivnuts into the fender and using anti-sieze on stainless screws.
Old June 4th, 2012, 09:54 PM
ghost1001's Avatar
ghost1001
Kevin M.
'87 110 sw, ex mod tdi
Why not use aluminium pop rivets.....alumininum to aluminium to aluminium seems the best way to go....no?
Old June 4th, 2012, 11:07 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
My vents fit inside the opening, but why not use longer screws and the same captive nuts?
Old June 5th, 2012, 10:37 AM
2411D90's Avatar
2411D90
Bob Vogler
1995 D90 Fastback ST (Beluga Black)
I bought some diamond plating from AB awhile ago, but haven't installed it yet. The kit included longer screws for the vents, and the instructions indicate that you need to remove the headlight assembly on the side with the evaporative canister to get to the captive nuts.
Old June 16th, 2015, 11:18 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
So 3 years later, any changes in advice on how to attach wing top protectors? Aluminum as not to create corrosion? Rivets vs nuts/bolts?
I have some leftover roll of thin rubber padding from when I installed hardwood floors at my house. I'm tempted to use that as a rattle barrier.
diamond, protector, top, wing
Wing Protectors and Sill Protectors (for a 110) ssegall77 For Sale - Parts 5 August 1st, 2008 09:47 AM
Wing Top Protectors Wolf Fabrication For Sale - Parts 3 January 1st, 2008 09:29 AM
Wing top Air Intake or Scoop??? adibitar Defender Technical Discussions 7 July 8th, 2004 08:57 AM
wing protectors Campbell Wanted 7 March 25th, 2004 05:21 PM
For sale: Daimond Plate Half Wing Protectors Burke For Sale - Parts 0 January 25th, 2004 11:20 AM
