Installing oil cooler thermostat - Defender Source
Old February 15th, 2005, 12:22 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Hans,
I have the mocal thermostat that goes under the oil filter base. Question: I've never removed the filter without first draining the oil. Will oil pour out if I remove the filter without first draining the oil? It's a bit early to change the oil on Chammy.
Any other hints or tips besides making sure I have the right AN size fittings?
DW
Old February 15th, 2005, 01:12 PM
No, the oil will not pour out. Land Rover has you drain and refill the cranckcase before changing the filter.
Old February 15th, 2005, 01:55 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Some oil will come out from the oil cooler, have a drip pan just in case. But it should only be the amount in the cooler, hoses and filter. The other 6 qts will stay on the oil pan. Figure about a half-quart or so maybe.
Also, you need to make sure you have the right fittings for that Mocal sandwich plate. If you have Part # SP1T like I have, It's 1/2" BSP female threaded, not a -AN fitting. Those type fittings require an extra sealing ring. The sealing face isn't chamfered on that plate, so you need this type seal.
http://www.pegasusautoracing.com/Pro...p?Product=3240
I wanted to put mine on the other day, but I am a bit leery over the fittings I have for the oil-cooler side. The stock oil cooler has 1/2" NPT threads, but the wrong type of sealing face on them. I was about to go check mine right now actually to try and figure that part out.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 15th, 2005, 02:07 PM
Doug's Avatar
Doug
Doug Walker
I asked Mocal to send me 6AN adapters with the SP1T, which they did (two male ends), and they also included a couple of sealing rings like in your link above. The hoses I'm using were made by Rover Accessories (refit for the original oil cooler hoses) and they told me they were 6AN. So I think maybe I'm good. Eyeballing it, looks okay. Will probably make a run at it this weekend.
Old February 15th, 2005, 04:20 PM
Hans's Avatar
Hans
Hans Haase
Wow, holy easy easy install if you have the parts already.
30-45 minutes tops if nothing breaks, pictures will be posted later tonight.
Already have them uploaded, but I need to shower and get going to work.
-Hans
Well, quick trip to work, and already I am glad I swapped in the thermostat. If nothing else, it gets the oil pressure up into the operating range much faster during startup. The oil pressure light goes out immediately, instead of the 2-3 seconds it usually takes. Right there is worth the money.
Anyways, some quick pictures and installation notes here on a web-page I threw together real quick before I left for work. I'll improve it later on when I get a chance. Feel free to ask questions.
www.siegecraft.us/rover.htm
-Hans
Oh, I also forgot to add. the Mocal sandwich plate appears to have a much better flow capacity than the stock piece. The passages are significantly larger and are also somewhat smoothed out as well to improve the flow even more. I used 1/2" ID oil lines in place of the factory ones, which should further upgrade the system.
I can't wait to add the new oil cooler this summer, but I haven't 100% decided on what to do with that yet.
-Hans
My oil line fix
Old February 15th, 2005, 07:43 PM
Doug's Avatar
Doug
Doug Walker
Great write up and photos, Hans!
Doug W.
Old February 16th, 2005, 01:02 AM
Hans's Avatar
Hans
Hans Haase
Just added some more text on the page, and resized one of the photos. Hope it helps. If our joyous host wants to add it to the tech-articles, he is more than welcome to use it.
-Hans
My oil line fix
Old February 18th, 2005, 12:32 AM
troutrover
Christian Beck
many
Where did you get the Mocal sandwhich plate and how much?
CB
Old February 18th, 2005, 12:43 AM
Hans's Avatar
Hans
Hans Haase
I ordered mine from a place called Racer Parts Wholesale, it came up a few pennies short of $90 including shipping and took about a week to get here. I'll add that to the website spot too.
My oil line fix
thermostat
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil cooler hoses rvrsrvc For Sale - Parts 116 October 16th, 2005 05:47 PM
External Oil Cooler jabber Defender Technical Discussions 3 August 21st, 2005 04:45 AM
How and Why to add an oil thermostat Hans Misc. Chit-Chat 0 February 18th, 2005 03:57 PM
