Installing Great Basin Rovers Driveshafts - Defender Source
Old February 19th, 2005, 11:09 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Hey gang, out in the garage putting on my new GBR HD driveshafts but have run into an issue. Starting on the rear, the adapter plate that bolts to the rear diff has a lip that prevents it form sitting completely flush. For those that installed these, is the little gapp supposed to be there?
Thanks!
Chris von C
[/size]
Old February 19th, 2005, 12:39 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Hey Chris
Doing a Double double Cardon jont?
The "lip" is it on the inside of the adaptor? The adaptor should have a "pilot" so that it centers on the pinion flange and fits flush... It is probably a tight fit... In no case should the adaptor be away from a flange unless it is supported by something... If so you will have a vibration..
You can call me if you like I've installed a dozen or so.. The # is on my website..
Keith
www.rovertracks.com
Keith
Big, Red and ... aaa Red..
Old February 19th, 2005, 06:58 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Thanks Keith, Bill from GBR called me back and got me squared away. Yes they are double cardons.
Chris von C
[/size]
Old February 20th, 2005, 08:28 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Chris, I just installed a front one. (The new one I bought on the site for $50 ) Had no problem. Like Keith said, it squeezes into the flange and sits flush.
Legend in My Own Mind.
Old February 20th, 2005, 09:35 AM
chrisvonc's Avatar
chrisvonc
Chris von C
You and your $50 deal of the year. ugh, I should have jumped on that one when I saw it posted.
Yeah the problem was that that it all fits together a lot better when you dont put the shaft on backwards. Once Bill explained that the double cardon ends are to be mounted at the transfer case, not the diff, things went a lot smoother.
Chris von C
[/size]
Old February 20th, 2005, 06:35 PM
Jase
Jase
pending
Keith is talking about the double / double, cardons on both sides and about $600.00
Old April 5th, 2009, 11:00 AM
chrisvonc's Avatar
chrisvonc
Chris von C
Digging up an old thread... Tony and I tried to mount my GBR front drive shaft yesterday only to find that it appears to be a difference in the mounting studs off the front of the transfer case between a 94 D90 and the 97's because these just dont line up with the holes. I had the shaft mounted on the 94 but it wont couple with the flange on the 97
Is this in fact true??
Chris von C
[/size]
Old April 5th, 2009, 12:35 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Is it an early GBR double cardon? If so it should have an adaptor from the output flange to the flange on the drive shaft.
I believe that the only other output flange I am aware of the was attached to an LT230 was the D2 type for the factory Double cardon driveshaft.
Keith
Old April 5th, 2009, 12:48 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
There are two different front output flanges. The later flange will allow you to run the shaft without a spacer. The earlier one will not as the holes are a smaller pattern. If you have the older style, I would buy a new flange rather than the adapter, as running no adapter is stronger and less headache. However, it may not be possible if the shaft is build shorter for the adapter. Clear as mud?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 5th, 2009, 01:04 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Hmm thanks guys..
I have one space plate with the front shaft that I swore came off the t-case/double cardon end when i pulled it off the 94. It will mount to the axle end but niether that nor the holes on the axle will line up at the t-case end.
Kieth I guess it might be.. I would say its about 5 years old.
Sound like Buck saying there are 2 different sizes is whats killing me here.
Chris von C
[/size]
Old April 5th, 2009, 03:40 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hmm thanks guys..
I have a bunch of stuff here if you need an old style flange, or old style adapter.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 5th, 2009, 06:44 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Cool Buck let me shoot you a PM.
Chris von C
[/size]
Old April 5th, 2009, 09:45 PM
huck1974's Avatar
huck1974
shane cates
94 d90
they quit using adapters now. The one I bought last year for the front had one. The new one for the back does not.
And hay
And I love you too
Old April 6th, 2009, 05:59 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Mystery solved.. Bill called me and turns out a little key info I didnt relay here was the drive shaft I pulled off is a D2 double cardon.. thus the different sized flange.
Chris von C
[/size]
Old April 6th, 2009, 07:17 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey Chris. I got your pm. If you can get ahold of the d2 flange, replace that and keep the dshaft. That's the better way to do it! Good luck.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 6th, 2009, 08:18 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Sorry.. the truck has the D2 flange on it already.. to put my GBR on, I need a stock D90 flange.
Chris von C
[/size]
drives, driveshafts, great basin rovers
Brand new GBR (great basin rovers) double cardon front driveshaft with adaptor evilfij For Sale - Parts 8 October 12th, 2009 01:39 PM
Great Basin Rovers? airbornrover Misc. Chit-Chat 6 January 8th, 2008 11:36 AM
Great Basin Rovers SLC UT 1of40 Defender Technical Discussions 5 December 26th, 2006 03:27 PM
Great Basin or Ashcroft 4.11 R & P Steve Friedman Wanted 1 July 4th, 2005 10:52 AM
Rovers in Kansas - Kansas USA chrisvonc Trip & Trail Reports 0 June 19th, 2004 08:43 AM
