Installing Extra temp. gauge - Defender Source
Old April 1st, 2010, 01:48 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Hey,
I have a 97SW and my temp gauge shots up when I run most of the power items....lights, a/c and heat. As soon as I turn them on it jumps to 3/4. I can't seem to figure it out but I know it isn't running hot. So I was thinking about installing a second one in the truck. Maybe digital. Has anyone done this and can you tell me how?
Rich
Old April 1st, 2010, 02:55 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I tried this too because I thought other things were effecting my temp gauge. If you do this you can only run one gauge off the sending unit. I ran two wires from the sending unit to the two separate gauges and it split the negative ground so both gauges read half of the real temp. You me just want to run a new gauge and hot wire it to a direct + line to see the true temp.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 1st, 2010, 03:38 PM
Campbell's Avatar
Campbell
Rich Campbell
I might have to do that. What are my gauge options.
Also, what if I just re-ran a new ground to the gauge. What would be a good source for that ground?
------ Follow up post added April 1st, 2010 07:47 PM ------
Does anyone know where the gauge is grounded?
diameter of stock temp gauge naeirie Defender Technical Discussions 2 March 2nd, 2005 06:34 PM
Temp gauge sender for '97? Chaucer Misc. Chit-Chat 6 February 24th, 2005 07:47 AM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
temp gauge ron Wanted 0 December 10th, 2003 12:44 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
