installing exhaust manifolds - Defender Source
Old June 17th, 2004, 08:20 PM
mattdh's Avatar
mattdh
Matt Hurst
got the maniffolds back from the coater today. looking for help on the insatll process. do i need to put any anti-seize in between the block,gasket,or manifold? can i use lock washer instead of the locking tabs-or not a good idea? can i use a stainless steel bolts here or is that not a good idea either? just to let you know(if you are curious) they are my factory manifolds and if any one wants i will post pics after the install.
Old June 17th, 2004, 09:28 PM
Are the faces (part that bolts up against the block) powder coated???
Old June 17th, 2004, 09:44 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
What kind off coating? Jet Hot?
Old June 17th, 2004, 10:26 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Matt,
YES, please post pics...
And I am curious too as to whether the 'faces' are powder coated ... ?
Nicholas Orros
Old June 17th, 2004, 10:35 PM
mattdh's Avatar
mattdh
Matt Hurst
yes the faces are coated-its a high temp ceramic coat like jet hot.the guy that did them,i heard he did jet hot for awhile then switched-i will have to ask him if thats true and if, so why?
Old June 17th, 2004, 11:07 PM
You want the "updated" hardware.
It came on 97 and up or so. They are longer bolts with spacers. Ask your favorite parts place for them
Locktabs are a PITA and lock washers will come loose.
You also want the metal shim style gaskets. I put high temp anti seize on the threads of the bolts. I am wishy washy on whether to recommend this or not.
Ron
Old June 18th, 2004, 01:13 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
Slightly off-point, but are there any "shorty" headers that offer better performance while attaching to existing exhaust? The stockers look so small and restrictive...that seems to be the chokepoint...or maybe the intake as well.
If not, what's popular for a header? I've seen plenty on exhaust recently...but not headers/manifolds...
I can just hear my engine wheezing trying to breathe better...help me...help it.
Old June 18th, 2004, 02:03 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I think you can get headers for Defender V8s from the usual UK places. Pretty much, one size fits all. Get a LR mag and look thru the ads. I decided against them because of the huge noise factor.
Old June 18th, 2004, 02:06 PM
mattdh's Avatar
mattdh
Matt Hurst
doug are you goin with factory 3.9 maniflods off your old 3.9 on your new 5.0?
Old June 18th, 2004, 02:16 PM
Doug's Avatar
Doug
Doug Walker
Yup. They are installed. The port sizes matched pretty close. If I find that they are too restrictive, I'll start researching a change. But I think it's going to be a matter of getting air IN, rather than OUT. Anyway, my goal is not to acquire all 340 hp out of this monster. I'll be happy to get 270 to 280 hp -- should be adequate for climbing the 395 into the High Sierras at 80mph, and beating hummers off the line on the Sunset Strip. I'm totally confident low rpm torque will be maxed with the existing manifold.
Comments welcome. Engine should be cranked for the first time within a week.
Old June 18th, 2004, 02:32 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I was considering headers for my truck but the more I look into it I am leaning against it. Cost is one issue, quality is the major issue, most header flanges are pretty slim and with time they will start leaking. Heat is another issue but can be cured with Jet Hot. Noise is also a big factor. I have decided to match port the existing manifolds and have them Jet Hot coated.
Old June 18th, 2004, 03:39 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Torrance, a friend of mine is installing Headman Headers on his 94 D90 with Summit Racing cats.
My partner had the same combo on his 91 RR and he did notice an improvement in performance.
You can get the Headman for $119 (uncoated) and $319 (ceramic coated). I had gotten a quote from Jet Hot for $299 to get them coated.
You can also get the Janspeed from the UK but they are pretty expensive. I don't have the price sheet in front of me but I could get you a price next week.
Just my 2 cents.
John C.
John C.
Old June 19th, 2004, 02:16 AM
Do they headmen bolt up or do you need a new y-pipe?
Ron
Old June 21st, 2004, 05:03 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
I'd lean towards something like that. Headers don't inherently lead to loud exhaust...it's the muffler/ resonator and pipe size that has more to do with that. You can get a lot more flow through without necessarily leading to a lot (if any) more noise...
I would be interested in knowing if it's a bolt-in...but my entire exhaust is pretty shot anyway, so it's not really a factor...
Thanks! I look forward to reading more.
Old August 10th, 2004, 01:12 AM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Matt, are those stock manifolds? I thought I read that the stock manifolds didn't take to coatings because the welds couldn't stand the heat. Do I remember wrong?
Jet-Hot cites on their website improvements in efficiency and power increases. Does it really, or just more advertising hype?
Old August 10th, 2004, 02:05 AM
mattdh's Avatar
mattdh
Matt Hurst
hi ken!! i hope thats not true about the heat?i have not ran the engine. and i wont know about the power increase because i put a 4.6 block in it --- so the increase could be the coatings-- ha ha ha..sorry for the delay on paying you, i will drop a check int the mail thurs or fri i promise unless you have a paypal account
Old August 10th, 2004, 02:08 PM
loykd's Avatar
loykd
Ken Loy
Matt, Oh, so that's all I need to do to get a performance increase? Install a 4.6? I'll swap out tonite! haha
Anyone else with experience on coatings? I remember some guys talking about this in another thread, but didn't see any comments after the install. (Nor did we ever see any pics of your beauty, Matt, but that's a different subject. ) Someone mentioned "street rod" experiences.
Old August 10th, 2004, 02:32 PM
JohnC
We got my friend's D90 back from the shop after installing the Headman Headers and there IS a noticeable performance increase, and it sounds good (throaty).
I'll try to get some pics tonite.
John C.
Old August 10th, 2004, 05:03 PM
loykd's Avatar
loykd
Ken Loy
Thanks John. I saw your post earlier on that. Any info on the Janspeeds? (I sent you an email btw)
Old August 10th, 2004, 06:07 PM
sweet photos..
exhaust
Ceramic Coated Exhaust Manifolds kingstonman For Sale - Parts 8 May 26th, 2009 01:28 PM
F/S Ceramic Coated Exhaust Manifolds Paul Grant For Sale - Parts 0 November 9th, 2007 05:33 PM
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
WTB used exhaust manifolds kellymoe Wanted 1 February 13th, 2004 01:51 PM
The sweet smell of exhaust!! bd90 Defender Technical Discussions 2 February 1st, 2004 07:46 AM
