Installing Dual Battery - Page 3 - Defender Source
Old January 31st, 2014, 10:05 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Not all battery brands will fit two units in the defender battery box... Which leads to my next question that I have always wanted to ask; what other brands than Optima will fit two batteries comfortably in the Defender battery box if you want to run a dual system without using optima batteries?
Originally Posted by Red90 View Post
You do t need to get an optima with dual batteries. Not sure how a discussion on dual batteries turns into a discussion on battery brands.
Old February 1st, 2014, 12:09 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
That aside, I'm far more curious about this $400 Odyssey situation. Is it really worth twice the price of a similar Interstate?
I got mine for around $350 from this place: http://www.batterysystems.net/
"Worth it" depends on what's important to you. For me, reliability is king and there is no better in my book than Odyssey. Considering that a dead battery could cost me a day or two of a once-a-year vacation, it's well worth the extra $150. After a dead Optima red top and later, a dead yellow top, I made the switch to Odyssey and haven't had a problem since. With my single battery, I have fewer cables, more space in my battery box, and a much cleaner setup that's easy to diagnose. If you are on the Blue Sea fuse panel bandwagon and have one installed in the battery box, you'll also find that you can access your fuses without having to remove the battery.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old February 1st, 2014, 12:15 AM
Any group 34 battery will work. You may need a small packer to get it clear on the bottom.
Old February 1st, 2014, 12:29 AM
And you could always put in dual Odysseys if you want. I've been happy with the Exide Orbital marine starting/deep cycles. Many years of hard use.
Old February 1st, 2014, 09:09 AM
87 D110 (Ruby)
I take 10yo's to hike Old Rag
Old February 3rd, 2014, 12:28 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Going on 4 years with the yellow-top optima's in my truck and no issues...
I will admit that they sit on a battery tender when they are not in use for more than a week or so as winter storage is what killed one of my old Optimas...
As to the single vs. dual...I tend to leave my lights on...so better safe than sorry...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old February 9th, 2014, 11:04 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
So D34 is a size denomination? You're saying then that the Odyssey and Exide are same size as Optima? I've had a Optima Yellow Top for 6 years and I have mixed feelings about it. If there's something better out there in the same size I'd like to know. I have two new Yelllow tops on the shelf in the garage that were supposed to go into my dual battery system but I'm hesitating. I have a battery box 'shelf' ready to install and I need to be able to fit the ACR and a fuse box as well.
Old February 9th, 2014, 11:05 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
My current Yellow top is 6 years old is not holding a charge very well. If I don't drive it for a while it needs to be on a tender. if I drive it daily its fine.
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Dual Battery setup (Painless Perf + extras) Ray_G For Sale - Parts 4 September 6th, 2011 07:10 AM
Dual Battery jijalicious Defender Technical Discussions 22 July 12th, 2010 11:47 AM
Simple Dual Battery Isolator? OCD90 Defender Technical Discussions 1 April 9th, 2004 11:23 PM
