Installing d90tops.com Hardtop - Defender Source
Old October 27th, 2015, 02:16 PM
jperakis
James Perakis
94 ST
Got my d90tops.com hardtop yesterday and I am running into some fitting issues.
Calls to the manufacturer have gone unanswered so I'll turn to the board for help.
The sides and rear corners fit well.
I followed the NAS fiberglass instructions and mounted those pieces first.
the roof piece is causing the issues.
The roof seems to get stuck on the roll cage (B/C pillar point).
The contact is essentially causing the roof to twist ever so slightly which causes about half the holes to not line up properly.
Any thoughts or suggestions?
remember two things...
Old October 27th, 2015, 02:27 PM
The guy you bought it from posted the exact same question. Post pictures already!
http://www.defendersource.com/forum/...elp-65127.html
Old October 27th, 2015, 02:43 PM
jperakis
James Perakis
94 ST
two things :
1. how the **** are you that good with the search function?!?
2. Unfortunately the referenced post does not address the fit issue I'm facing.
Admittedly I did excitedly rush the install process so perhaps I'll remove the roof and take a little bit longer.
Old October 27th, 2015, 02:52 PM
ok well take your time taking pics and post up. Considering this is a repeated issue, you'll be helping out others when the next person posts a new thread.
Old October 27th, 2015, 11:40 PM
CDeWan
Clay DeWan
5.3L beastie
just a thought
When I did the install of a original LR fiberglass hardtop, I bought some foam stripping about 1/8 or a little thicker and about 1 inch wide. I put these between the sides and capping and between the top of the sides and the top basically to lessen the parts rubbing against each other and also so seal the top better. This may give you just a little lift (very little) but may be enough or you could go with a little thicker foam.
Old October 28th, 2015, 10:49 AM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
I had the worst experience installing my D90 top. None of the holes lined up. Had to trim a lot of material where the sides meet with the top around where the A-pillar meets the B-pillar. The back door still doesn't open as much as I would like. Haven't figured out how to make it open up farther. All I can say is good luck and Andy at D90tops is a good guy and I'm sure he will make this right.
When the F*%# did we get Ice cream!!!
"They are, in factory original condition, noisy, they leak water in from the top and oil out from underneath, you can never demist the windows in winter, they handle like scaffolding towers, and use more fuel than Beijing." Richard Hammond
Old October 28th, 2015, 09:02 PM
D110DC's Avatar
D110DC
Pete
66 SIIA, 70 IIA, 97 D90
James,
I had the identical issue with my d90 top. Right side B pillar cut around roll bar would not fit not matter what. Had to send the whole thing back to have it redone. What I got back did fit, but other parts now had issues. Manufacturer not helpful and wouldn't support any further changes.
I have since trimmed and inserted some foam, and it now works well (as long as you seal every place the top touches).
Pete
Pete
1966 ECR Series IIA
1970 Series IIA (Stella)
1997 D90 ST
2011 LR4 HSE
2010 Range Rover Supercharged
Sadly gone (some more sadly than others):
1983 D110 Double Cab 300 TDi
1989 RRC
1996 D1
2006 LR3
2008 RR
Old October 28th, 2015, 09:07 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Surprised to hear these issues on this expensive top. In the rare ass chance I ever spent thousands of dollars on a top, the manufacturer better do all they could to make it right or I would assume they would never stay in business.
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
90, d90, hardtop, top
D90tops Parts jperakis For Sale - Parts 3 October 27th, 2015 02:25 PM
D90tops.com Install Help NAS Addict Defender Technical Discussions 19 September 24th, 2015 04:05 PM
D90tops Roverlab Defender Technical Discussions 6 June 13th, 2012 07:03 PM
d90tops.com d90boy Misc. Chit-Chat 5 November 3rd, 2011 09:58 AM
Help with installing hardtop Chris Cox Defender Technical Discussions 4 November 24th, 2004 04:56 PM
