Installing Brake Controller--where to tap into brakes - Defender Source
Old May 15th, 2014, 10:55 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
For the wiring for the Brake Controller, I need to tap into the brake signal--I know where it comes out of the back of the brake box in the engine compartment and goes into the wiring harness (green with purple stripe, I believe) but I didn't know if that was also available somewhere more convenient in the cab. I have looked at the fuse box--and I will again, and I can always tap in at the brake box, but I was hoping there might be a wire behind the instrument cluster or in the cabin. If any of you know, please do tell! Thanks--
Old May 21st, 2014, 10:33 PM
Jas0n's Avatar
Jas0n
Jason
1995 D90 SW #421
Bump - looking for the same answer ...
Does anyone know if there's the same grey plug under the dash as there is in the D1? Also, what's the easiest way to get at the plug if you have factory air conditioning?
Old May 22nd, 2014, 08:09 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I finally just tapped in off where the wires come out of the booster under the hood, FYI.
Old May 22nd, 2014, 08:11 AM
Jas0n's Avatar
Jas0n
Jason
1995 D90 SW #421
Did you happen to check if there's a grey plug under the lower dash on the left side of the column?
If so, it should jus be plug and play. My 90 is in the shop otherwise I'd check. Either way, seems like a write up will be helpful for others, so ill take a stab at it next weekend ...
brake
LR3 incognito brake controller? Broncoduecer Misc. Chit-Chat 16 May 5th, 2013 03:52 PM
Tekonsha Prodigy brake controller Abrooks The Flea Market 14 March 9th, 2012 02:17 PM
Recommended Location for Brake Controller on D-110 NomaD110 Defender Technical Discussions 4 February 7th, 2012 01:15 AM
Advice on fitting a US-seven pin and electric brake controller onto a '83 110? turbodave Defender Technical Discussions 4 June 25th, 2009 02:48 PM
