Installing anti-crush spacer into frame - Defender Source
Old May 3rd, 2015, 11:03 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Need to install some anti-crush spacers into my frame rails for my t'case relocation. Thought about drilling a 1" hole and slotting some 1/2" pipe pieces into the frame & tap into place.
Any other good ideas or suggestions ?
Old May 3rd, 2015, 11:29 PM
That what I do and then weld them. You obviously only need the large hole on one side.
Old May 3rd, 2015, 11:36 PM
Landy_Andy's Avatar
Landy_Andy
Andy
That's what I was thinking, couple of small holes either side of the bolt hole and a plug weld in each to secure the tube on one end.
Old May 5th, 2015, 01:44 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Got it done, a few pic's of the process. Drilled some plug weld holes either side of the bolt hole using a washer as a quick guide.
Opened the holes up to just over the 1/2" sch'd 40 pipe wall thickness that I had cut into 72mm long pieces.
Worked the pieces of pipe into the correct location & then plug welded both ends into place.
All in all took about 3hrs from start to finish, well worth the time to do a good job
ac
Orange Crush (Kermit) kenn73 Misc. Chit-Chat 5 July 14th, 2016 09:39 AM
95 RRC Rubber Crush Can Covers Toughy Wanted 0 December 9th, 2014 11:53 PM
Wheel spacers and Crush can covers Toughy Wanted 0 May 1st, 2014 12:14 AM
Intermediate Shaft Crush Sleeve - Different Ones? Wolf Fabrication Defender Technical Discussions 0 September 13th, 2010 05:16 PM
Looking into buying and installing this little gem airbornrover Misc. Chit-Chat 4 November 3rd, 2008 12:51 PM
