Installing A/C on a older euro d-90 ????? - Defender Source
Old May 8th, 2009, 07:48 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Has anyone wired an older d-90 for A/C? What is needed? I have a complete new Kit and need to wire it to an older d-90 without the plugs in the footwells like on a NAS truck. Any advise would be great...
Legend in My Own Mind.
Old May 8th, 2009, 08:50 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
engine ?
- Charles Eames
Old May 8th, 2009, 08:52 AM
Randy I have not done this, but I expect it will be stand alone. All it needs is power and ground like anything else, and all other controls and functionality are self contained. Since it doesn't have an ECU you can be assured there is nothing fancy like it knowing when the AC is on or something.
Old May 8th, 2009, 02:12 PM
It is stand-alone, but depends on what kit you have. If there are a couple connections which stymie you then they are probably inputs from high and low temp switches.
Old May 8th, 2009, 08:18 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Cool. It will be installed on my 300tdi truck. That sounds simple enough. I will keep you posted if I have any questions.
Old May 8th, 2009, 09:03 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I don't know if the V8 A/C has it, but on the Tdi A/C there is a little electronic control box
just behind the fan and temp. switches.
I have the wiring diagram of the Tdi A/C in case you need it.
- Charles Eames
Old May 14th, 2009, 08:51 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
The plug for the a/c has 3 wires brown, blue w/ black stripe, and white w/ green stripe. Its a 300tdi a/c assembly. Any Ideas Anyone?
Old May 15th, 2009, 11:03 AM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Randy,
make sure you post what you end up doing on this...and, what kit (source and part number?) did you buy?
George
Old May 15th, 2009, 04:27 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Randy, what do you want to know exactly ?
- Charles Eames
Old May 15th, 2009, 08:32 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Are the wires all the same gauge? The Germans like to use brown for ground, so that would be my guess (especially if it is made by BEHR). Aside from that, I would assume a large gauge wire would go to 12v and if there is a small one it is probably a remote wire, or an illumination wire, but this is all speculation. Hopefully someone has a wiring diagram or experience?!?!
90, d-90
Euro 90 Swingout tailgate / POE liftgate install dave_lucas Smaller Projects 24 March 14th, 2016 04:01 PM
1994 Defender 90 - Hardtop and A/C silver_defender For Sale - Vehicles 4 August 14th, 2009 03:31 PM
Installing '95 A/C in '94 jaherring Defender Technical Discussions 23 August 29th, 2005 08:12 PM
Installing a/c belt Campbell Defender Technical Discussions 2 May 7th, 2004 09:11 AM
94' Defender 90 A/C unit RX6RCROL For Sale - Parts 6 March 19th, 2004 08:41 PM
