Installing a/c belt - Defender Source
Old May 7th, 2004, 07:24 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Installing a/c belt
Can anyone offer me instructions on installing an A/C belt for a 1994. Does the fan have to be removed?
Rich
Old May 7th, 2004, 08:24 AM
Rich its not that hard, you have to remove the main water pump belt by loosening the tension pulley (theres a bolt on the bottom of the pulley where it attaches to the engine) and take that belt off. then you can slip the AC belt on and get that tight, then reassemble the main water pump belt.
The hardest part is getting to the bolt that holds the water pump pulley tight, you can see it best from under the 90.
Old May 7th, 2004, 09:11 AM
Campbell's Avatar
Campbell
Rich Campbell
Thanks Mike.
Installing A/C on a older euro d-90 ????? TDI Guy Defender Technical Discussions 9 May 15th, 2009 08:32 PM
Installing a belt rail system on a 94 Black_and_Blue Defender Technical Discussions 1 April 17th, 2007 09:27 AM
Installing '95 A/C in '94 jaherring Defender Technical Discussions 23 August 29th, 2005 08:12 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
can I remove a/c compressor belt? Campbell Defender Technical Discussions 20 November 1st, 2003 10:07 AM
