Installed Momo wheel and hub, now have clicking noise whenever wheel turns - Defender Source
Old August 29th, 2013, 11:26 AM
bradfordish's Avatar
bradfordish
Bradford
95 D90 SW #141
I recently installed a momo steering wheel (wanted something smaller) and the #5607 hub. Ever since then, I have a clicking/noise whenever I turn the wheel in either direction. It's not just once, the more I turn it will click/crunch again, and then when it turns back. It sounds like it may be coming from the signal lever. I have taken the hub off, check it out and reinstalled and the noise persists. Thoughts? At this point I'm likely going back to my stock wheel as this is driving me crazy.
Old August 29th, 2013, 05:21 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Check to see if the Momo adapter is touching the plastic surround/fascia. Where the surround comes together is a seam of plastic that may have to be ground down. The tab on the hub does sit inside the little blue ring for the turn signal cancellation, but really shouldn't make any noise. I did have to shorten a tab once because it was too long for the blue ring.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old August 30th, 2013, 03:26 PM
bradfordish
Bradford
95 D90 SW #141
I shaved down the plastic surround prior to the original install and it doesn't look like it is touching.... guess I'm going to need to shorten the hub tab.
Old August 31st, 2013, 08:38 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
When I used a RR adapter on my defender - the tab broke off when I tightened it down. But there is a fix for that.
Chris Hinkle
Old September 1st, 2013, 03:21 PM
CDeWan
Clay DeWan
5.3L beastie
Doesn't your mono have a molded turn signal reset ring? If so that may need to be shaved
Old September 3rd, 2013, 10:34 AM
bradfordish
Bradford
95 D90 SW #141
Ended up shaving down the plastic bezel and breaking off the turn signal reset ring. Much better but still some noise when the wheel is turned enough for a u-turn. I've also noticed that my horn and flash high beams no longer work. Checked the fuse which was fine, could the steering wheel have messed up the turn signal/horn/lights switch?
Old September 3rd, 2013, 10:39 AM
if I'm reading this right and you broke off the blue turn signal reset ring its a very good change you broke that multi switch which is your horn,turn signals, and dimmer switch. Why would you break that ?
Old September 3rd, 2013, 10:40 AM
bradfordish
Bradford
95 D90 SW #141
I didn't break the blue ring, I broke the tab off the momo hub trying to shorten it. The blue ring does seem to move independently though, is this normal?
Old September 3rd, 2013, 07:46 PM
independently ? its supposed to float and just rides on the tab of the steering wheel. If it gets off center the turn signal stalk wont lock into position on the side it falls to which can be annoying. Strange you lost all function from that stalk. Any chance the plug may have come apart ?
wheel
Momo Steering Wheel Hub Adapter Doug Crowther For Sale - Parts 10 November 7th, 2007 06:34 PM
Momo Wheel and Hub Adaptor Bozman Defender Technical Discussions 4 September 25th, 2006 10:30 AM
Momo Hub Adapter mchombeau Wanted 0 May 3rd, 2005 09:40 PM
another momo hub adapter question dnewman9 Defender Technical Discussions 0 October 3rd, 2004 08:46 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
