Install Thread for PS Gear Box - Defender Source
Old June 7th, 2012, 06:57 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Has anyone wrote anything up on how to install a Power Steering Gear Box? If so, Where can i find it? I am going to install my new unit tomorrow and was looking for some simple advice and some dos and don'ts. Thanks in advance.
Old June 7th, 2012, 08:16 PM
I'm not aware of any, but the on line copies of the repair manual should come in handy if you have any problems.
Old June 11th, 2012, 10:45 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
It's pretty straight forward as o2batsea said. It's worth noting the position of the drop arm of your current one when the steering wheel is centered. I believe the steering box itself is "centered" 3 complete rotations from the max right. It can be centered after it is installed, before you hook up the drag link and after you hook up the steering column (simply max it out all the way to the right, then spin the wheel back 3 turns). It can also be done with a pair of pliers before the box is installed.
Hook everything up, then bleed it. Don't open the bleeder more than you need to, or you may experience the full power of a power steering geyser.
Old June 12th, 2012, 07:43 AM
No real good install ones, but a good uninstall one from the other day over on ROVERS - at the bottom, and I think the next page:
http://forum.roversclub.org/forum/sh...-rebuild/page5
Old June 13th, 2012, 11:30 AM
Put the steering shaft onto the steering column before you bolt on the box with the four big bolts.
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
Tuffy box removal/ Rear load mat install aosias Defender Technical Discussions 5 March 7th, 2008 06:16 AM
howling trans or Transfer case? Gkase Defender Technical Discussions 18 February 8th, 2008 11:08 AM
300 TDI w Auto Gear box / Transfer Case SafariHP For Sale - Parts 0 January 2nd, 2007 09:23 PM
Thread hijacking! TwisteD90 Misc. Chit-Chat 19 March 6th, 2004 03:23 PM
