Install question: Safari HP aluminium dash cowl - Defender Source
Old March 1st, 2015, 09:10 AM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
I am looking forward to installing Safari HP's aluminium dash cowl as I'm tired watching my cracked OEM plastic cowl bounce all my instruments around on dirt roads....
To prep for install, is there anything I should know prior, from those who have done this? What, if anything, do I have to disconnect? Any pics? Any hints?
I searched around and found some posts mentioning, but didn't find anything that solid, so I wanted to ask.
Thanks for the help
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old March 1st, 2015, 09:16 AM
Rufus's Avatar
Rufus
Rufus
Here is another pic (borrowed from other posts)
Old March 1st, 2015, 09:46 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Really easy to fit, I did put some double sided foam tape on the back side before bolting it down. Just thinking it would help do away with any vibrations
One of the best mods thats out there.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 1st, 2015, 10:31 AM
grnrvrs's Avatar
grnrvrs
Paul
88
That pic was from my install, years ago. It was super easy and we'll worth it. I found a stubby Phillips helpful. All very straight forward.
1970 SIIA 88, Sold
Old March 1st, 2015, 10:43 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Nice. I'm waiting for them to get more of them in stock. I ordered the Raptor one but I may hold out for the aluminum ones to be available
Old March 1st, 2015, 11:08 AM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
The Safari HP cowel is the bees knees. Excellent fit.
Pick up some packs of ne self tapping screws, countersunk and the washer type to complement your install.
I had to replace the instrument bezel as the bottom tabs were cracked, Safari also supplied this. This meand that I had to disconnect the speedo. Try as I might I could not get it to come appart by pressing in the little white finger tabs, In the end one brioke and them it came apart. Reinstalled with a few wraps of insulationg tape and a small hose clamp. No problems since.
Eric.
Old March 1st, 2015, 11:33 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I have some pics of mine bolted in on the bulkhead thread. One thing I had to do was go back and drill a hole for the vent screw (they are in red circles on your 2nd picture). I wasn't sure why mine didn't have them drilled already? Mine might have been a 1st gen run of them (it's been sitting on my shelf for years).
Old March 1st, 2015, 11:55 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
The one I installed a year a go had the holes ready. One thing that is helpful is to get a new rtc3748. That's the plastic nut insert that the side trim/heater control fastens down with. Most likely the old one will break if you remove it.
Old March 1st, 2015, 04:08 PM
Rufus's Avatar
Rufus
Rufus
Thanks all helpful hints. How far out can I pull the instrument bezel with out disconnecting speedo, etc. I just need a little more room to play with in order to remove old, and install new, cowl and want to avoid disconnecting anything (in fear of breaking old brittle plastic parts).
Thank God the instrument bezel tabs aren't broken... Now that it is accessible, on the bezel tabs, I may epoxy in an aluminium back plate to reinforce it and make the tabs stronger (something I have done to fix John Deere plastic parts and it works well).
corduroy dirt roads can be just brutal on the older brittle plastic parts.
Old March 1st, 2015, 04:19 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
My memory is a little vague as I helped my old man install one on his 94, years ago. All we did was undo the top dash, steering wheel off. We didnt disconnect any of the electrics or gauges on the panel.
Old March 1st, 2015, 04:42 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Just to replace the cowel you do not need to disconnect anything from the instrument bezel or remove the steering wheel. The bezel will pull towards you a couple of inches which is enough to remove the old cowel (after removing the horizontal bar underneath) and insert the new one.
Just free everything off and it will be apparent.
However, if you notice any suprises behind, like ratty wiring or such, access is much easier with the bezel off.
Eric.
Old March 17th, 2015, 05:32 PM
Rufus's Avatar
Rufus
Rufus
Just to circle back on this - I took step by step pics of this install for the group because I realised they don't exist (or I couldn't find them). I am thinking I should post them under "smaller projects" or I could post them to this thread or both
Old March 17th, 2015, 05:35 PM
smaller projects would be best
Old March 18th, 2015, 01:52 PM
Rufus's Avatar
Rufus
Rufus
I posted the install pics under "smaller projects"
http://www.defendersource.com/forum/...-hp-60747.html
Old June 7th, 2015, 08:14 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
This is awesome. Thanks for posting!!
dash
WTB LHD Instrument cluster, cowl, and cowl stiffener flananuts Wanted 0 September 23rd, 2014 04:31 PM
Aluminium Dash Cowls Back in Stock SafariHP The Vendors Loft 0 February 1st, 2011 09:32 PM
Safari Rover Aluminum Dash Cowl James Pierce For Sale - Parts 5 December 6th, 2010 11:25 AM
Series III Instrument Cowl in Aluminium SafariHP The Vendors Loft 4 August 13th, 2010 09:06 AM
Aluminium Dash Cowl BAck in Stock SafariHP The Vendors Loft 27 August 12th, 2010 11:07 AM
