Install AC in 95 ST - Defender Source
Old October 1st, 2012, 08:17 PM
MAC
Max
'95 ST
Install AC in 95 ST
Hi all,
I'm considering a 1995 ST with no AC. Can someone give me a rough idea of what it will cost to buy the necessary parts and have someone install AC?
Old October 1st, 2012, 08:31 PM
800-1000 for the parts second hand .. Maybe a bit less ... Install should be a about a days work for someone who knows what they are doing ... And that might be your challenge.
A 95 system is slightly different from a 94 .. They can be made to fit but it's not plug and play.
It's not that difficult to do ... As a DIY job ... A lot of the part are old now so can be a bit fragile.
Old October 1st, 2012, 09:18 PM
a little over $1k with a fully functioning compressor, and about $1,400 near the top-end for a nearly perfect (for its age) complete A/C with everything.
Old October 1st, 2012, 09:27 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
New systems are in the 3K to 4K range complete. The newer systems are far better than the older ones.
Land Rover 110
95, ac
94 ST AC into a 95 SW leastonce Defender Technical Discussions 8 August 7th, 2010 08:17 AM
AC install confusion- a little help please aosias Defender Technical Discussions 6 January 3rd, 2010 05:18 PM
AC Install aosias Defender Technical Discussions 8 February 11th, 2009 02:23 PM
Looking to swap 95 ST for 95 / 97 SW unit3a Wanted 0 November 28th, 2008 12:55 PM
AC Unit from a 95 ST boshea For Sale - Parts 15 August 29th, 2004 11:33 AM
» Defender Registry
Bess
Yorkie
Roverin
rvrchuck
Add your Defender
