Inside Door Panel Reinforceing - Page 2 - Defender Source
Old April 6th, 2006, 07:08 PM
Trevor Tarr's Avatar
Trevor Tarr
Trevor Tarr
1997 D-90 4.6 NAS ST
Originally Posted by kellymoe
BTW Trevor, I am heading out to the Saline Sat-Tue
Lucky you. I won't be there for another 3 weeks, April 28-30.
Old October 15th, 2006, 10:53 PM
Backstay
John Hilton
1994 D90
Did anything ever come of the door panel reproduction?
I'd love a pair!
Old October 16th, 2006, 08:30 AM
themaxx's Avatar
themaxx
Ade
94 ST
I'd love a pair!
John, I'm not sure if Trevor ever fab'd anything, but LenB is currently working on sets of new Door Panels with speaker boxes, rear speakers boxes, seat rails, center consoles and a few other cool accessories. Get in contact with him.
http://www.defendersource.com/forum/...hp?userid=1059
Here is some of his work...
ID:	7072   Click image for larger version
ID:	7074   Click image for larger version
ID:	7076   Click image for larger version
Old October 16th, 2006, 08:50 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
I'm in for upgraded door cards for SWs . They would have to be gray! can you guys check into color options?.
The above alu panels look like their made for series type of door, is he making sets for D90s?, it's all good IMO.
Old October 16th, 2006, 09:27 AM
blinded by the bling. Looks good. Are those wing top intakes gonna be availible?
Old October 16th, 2006, 10:02 AM
themaxx's Avatar
themaxx
Ade
94 ST
Yes, Len is making sets for the D-90s. I'm not familiar with what the differences are between the SWs and STs, but I'm sure if you contact him, that can be worked out.
As far as color choices, I myself was thinking about either having it powder coated or Line-x'd. Both options allow you choices of colors!
The intakes are also available!
Old October 16th, 2006, 05:57 PM
Trevor Tarr
Trevor Tarr
Originally Posted by themaxx25
John, I'm not sure if Trevor ever fab'd anything....
I did. Not as professional-looking as Len's work, but I'll take some pictures.
Old November 15th, 2006, 04:21 PM
Trevor Tarr
Trevor Tarr
Here are a couple pictures of my completed install. The gooey black stuff you may notice around the panels' edges is "B-Quiet Ultimate" (http://www.b-quiet.com/ultimate.html), a viscoelastic sound-deadener. I applied it to both the inside of the door frame, and the inside of the new panels.
Because the panels are flat, without the contours of the OEM plastic, there wasn't clearance for my midrange drivers, so I fabbed aluminum standoffs. (They bear a remarkable resemblance to pie tins, don't they...?) I pulled the door pockets off the plastic panels, and mounted them to the chequeur plate. My panels don't extend all the way up to the window. I fabbed trays to fit in the recess under the door curve. I relocated the door handles rearward slightly.
I'm still having some resonance issues with my speakers. Not sure yet if it's in the standoff-to-panel interface, or panel-to-door.
Name:	Door panel left 1.jpg
ID:	7419   Click image for larger version
Name:	Door panel right 2.jpg
Old November 15th, 2006, 04:39 PM
trislerjw
JT
97 D-90 ST
Doors
Looks good Trevor, Good Idea on the trays. Thanks for the pics, It will help me out a ton when I start in on mine.
What thickness of 5 bar did you end up using?
-Jason
Old November 15th, 2006, 04:57 PM
Why not use SIII door panels? They are cheap and look pretty nice. I am thinking about fabbing some up out of masonite and covering in vinyl for the 110.
Ron
Old November 15th, 2006, 05:03 PM
Trevor Tarr
Trevor Tarr
Not sure on the thickness. I got the five-bar from Industrial Metal Supply, and I believe they had two thicknesses available. I chose the thinner of the two, and would probably switch to the thicker if I was doing it again.
Never thought of that. Ron, how are they different from Defender panels? Are they flat?
door
exhaust fumes inside cab! problem solved. johnpiero Defender Technical Discussions 42 July 15th, 2009 08:26 AM
Where can I find the pads that go on the cage bar inside the SW? Pic inside... KKilo23 Defender Technical Discussions 6 June 26th, 2009 05:36 PM
Misting on the inside Andrew Vick Defender Technical Discussions 31 March 10th, 2008 07:27 PM
Universe inside of a Univers cbass Misc. Chit-Chat 0 June 9th, 2005 05:30 PM
Inside door storage bags Campbell Wanted 0 March 13th, 2004 10:17 AM
