Good Day Dear All....
This case might be discussed in early in some topics. Sorry if discussed in another pages.
My LT230 has leakage (80W90). Oh sorry not leaking "It marks its territory":grin:grin:grin
But too much territory. :mad
I inspected the leakages where it comes. I found two leakages. One is from flange of front shaft. I fixed it. Because it was very easy.
But other leakage comes between LT230-R380.
I bought full kit of gasket. I will remove LT230 and I can change the gaskets and packing where necessary.
I have an idea :hmm Most probably some had already.
I can remove the input gear from case. I think, it is not the type of cross-drilled.
Shall I drill cross this input_gear on turning machine with drill bits for better lubrication ? such as attached picture.
I think it is necessary to make it oil+water while drilling in very slow speed and using different type of drill bits.
Your advise, comments and experience if you had, please share with me. I will be appreciated.
P.S.: LT230 Transfer Box Oil Feed Plate is not available in Turkey
Thanks and Best Regards.
Murat
Murat
