Input Gear Bearing P/N? - Defender Source
Old April 24th, 2009, 04:02 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Anyone have the Timken Bearing P/N for the input gear front and rear bearings?
~Scott T.
'95 D-90 ST - AA Yellow
Old April 24th, 2009, 04:48 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
http://www.defendersource.com/forum/...ead.php?t=5596
"Just for the record the input shaft (Mainshaft Transfer Gear) bearings are FRC5564 Land Rover which cross refs to 18790/18720 Timken and a few other decent Jap Brands."
Old April 25th, 2009, 12:13 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Thanks, not sure how I missed that in my searches..
~Scott T.
Old April 25th, 2009, 04:13 PM
landrovered
S. Smith
Search does not always yield good results especially when the nugget of information is buried down in the thread.
I would like to see a sticky with all the commonly used parts cross referenced to their manufacturers numbers. Is there such a thing?
Bearing removal on a t-case input gear TDI Guy Defender Technical Discussions 8 September 28th, 2009 07:06 AM
Transfer box input bearing preload reb78 Defender Technical Discussions 10 October 29th, 2008 05:04 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
T-case input shaft Bearing #s Mike Hippert Defender Technical Discussions 10 June 8th, 2005 06:52 PM
