Inner hub seal seating depth - Defender Source
Old December 6th, 2005, 10:06 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
RTC3511 inner hub seal, should this be seated deeper?
Name:	inner hub seal.JPG
Old December 6th, 2005, 10:30 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Yes,
If you read the printing on the seal, it says to seat it 3 or 4 mm below flush.
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 6th, 2005, 11:39 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Oh Deeper Deeeeper Deeeeeper Oh Baby! Over!
Old December 6th, 2005, 11:43 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Originally Posted by Roadsiderob
Yes,
Rob
When all else fails.......read the instructions.
I never knew there were any printed on the seal!
Probably because I tend not to buy genuine
Mike Hammond
Old August 13th, 2009, 10:22 AM
I'm fitting the rtc3511 to my rear salisbury (and converting to rear discs), and it looks like it fits differently than my original seal -
Does the seal change shape as it goes in?
Is there actually some of the bore showing once the seal is completely seated?
I found this pic on lr4x4.com of a front hub - does this pic correctly depict the proper fit?
Old August 13th, 2009, 10:43 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Since I originally posted I've probably done a half dozen of these. Yes, it does change shape a bit as it seats, IMO the pic is just right.
Old August 13th, 2009, 10:44 AM
Sweet, thanks!
What do you use to seat it properly? Not the -gasp- special tool?
Old August 13th, 2009, 11:01 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
i use the old seal to seat it
3rd low and BOOT IT
Old August 13th, 2009, 11:48 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Jimmy's method or a piece of PVC pipe works. There is a metal core to those so you can get away with gently tapping it in with a flat screwdriver on the flat part and working around it in a circle.
Old August 13th, 2009, 12:42 PM
Knock it in until it touches the bearing. Simple....
Old August 13th, 2009, 01:13 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Pic 1) 4mm deep
Pic 2) Use the drive flange to seat it
Pic 3) But don't drive it home, there will be a bit of a gap between flange and hub.
ID:	21065   Click image for larger version
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 13th, 2009, 01:21 PM
That's great Tom - I edited your post to add the pix.
Old August 14th, 2009, 08:26 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have the FANCY LR installation tool....
Thats a great Idea Tom..
Legend in My Own Mind.
Old August 14th, 2009, 08:35 AM
I re-did the hub last night, and found that an old bearing race was the perfect size for inserting the seal. So that's what I used, but I'll probably end up buying that tool. Because I am a tool.
Old August 14th, 2009, 10:40 AM
There are two rear hub seals, the double lip one and the not double lip one. IIRC the double lip one was a remnant from the wet hub days and that is the better of the two, but if you are running grease in the hubs, it does not matter much.
Old August 14th, 2009, 12:22 PM
Antichrist's Avatar
Antichrist
Tom Rowe
If the "not double lip one" is the one fitted to Disco's (FTC4785), it's a PoS, IMO.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 14th, 2009, 01:15 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
The only great seal is the RTC3511 the FRC8221 is good the Disco ones are nearly useless if you wheel at all.
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old September 9th, 2009, 10:09 AM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
I'm using the 3511 seal on the rear of my 1989 RRC where I have wet hubs. I just did a toyota conversion a few months ago and at that time I got new hubs with all new bearings and these seals.
When I was doing that job, it became evident that I needed new brakes all around. I just started to do the rear brakes and I was hoping to gently remove the hub and keep the seal in place to reuse since it is so new. When I took off the hub, a small round wire remained on the spindle.
How important is this wire? Should I just order some new seals or do you think I can reuse this seal even though the wire came off? thanks
ID:	21400   Click image for larger version
Old September 9th, 2009, 10:12 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
That wire is a tension spring for the seal, I'd use a new seal.
Old September 9th, 2009, 10:13 AM
Gore Ranger
Jeff
1989 RRC
Ok, I was hesitant to replace initially because they were like $15-20 each, but it looks like British Pacific has them for about $5 and I need to order some other stuff too
I will go ahead and order a few new ones.
Front hub seal bjf Defender Technical Discussions 7 March 17th, 2009 01:01 AM
series front hub seal airbornrover Series Technical Discussions 1 November 12th, 2008 08:48 AM
93 NAS D-110 Diff oil and Hub Seal Questions AHollander Defender Technical Discussions 16 October 23rd, 2007 02:46 AM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
» Defender Registry
Old Rover
RBBailey
D90
NPT90
Add your Defender
