Inline fuel filter with diesel? - Defender Source
Old January 9th, 2008, 09:23 AM
Heres a pic from an ECR project - they've used the V8 fuel lines and have an inline fuel filter in the stock position. I wonder what the effect of that is? Won't it have to be changed kinda often? I have to change the larger diesel one every few thousand miles.
Does Mike have an explanation?
Old January 9th, 2008, 10:24 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Hi Jim, I think you forgot to attach the pic?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 9th, 2008, 10:39 AM
Not possible!
Old January 9th, 2008, 12:13 PM
Shane@EVS
Roverhybrids
I can't say what ECR is doing but you can get a strainer to put in place of the factory gas filter, though the ones I have seen are just barbed and not the same fittings as the V8 version.
Old January 9th, 2008, 12:29 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Its not a filter.
Its a SS canister that looks like a filter so that we can use the same production CNC made SS fuel lines on both the gas and the diesel.
Email:
Old January 9th, 2008, 12:31 PM
At least you dont have to replace it.
Old January 9th, 2008, 12:55 PM
All well and good until someone takes it to a shop other than ECR and asks to have the fuel filter changed . . . .
Old January 9th, 2008, 01:05 PM
ECR's Avatar
ECR
Guess that would be a pretty stupid mechanic considering it says "Not a filter, do not change" on it and the customer is made aware of what it is as well.
If you don't like it you are welcome to pay all the set up costs in order to make a new supply line just for the few NAS diesels out there. Oh yeah... then folks would complain that the stainless lines for the diesel costs to much.
Most Tdi conversions I have seen done by other places have a piece of rubber hose fitted in there and that will decay. At least this solution is a long term one, being all stainless.
Email:
Old January 9th, 2008, 01:20 PM
Works for me, since it looks like a good place to splice in for a second fuel tank.
Mike - What do you do for stainless 110 brake lines?
Old January 9th, 2008, 01:22 PM
ECR's Avatar
ECR
Same as the other lines. Classic Tube makes them for us, stainless lines with stainless fittings. Most other places offer stainless lines with standard steel fittings.
Email:
Old January 9th, 2008, 04:16 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Do Not Change!
legend in my own mind
Old January 9th, 2008, 05:37 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
That's a good use of the stock fuel line with the diesel conversion. You could easily turn it into a pre-filter like what is fitted on many Mercedes diesels from the factory. See my post here about the pre-filter that I installed on my TDI Jetta: http://twowheelphotos.blogspot.com/2...re-filter.html
If there is a pre-filter, the purpose of it is simply to catch any large particles >150 microns before they get to the main filter, thus prolonging the life of the main filter. Mine has caught a few visible particles already, and in addition, it lets you see the state of your diesel fuel on those cold days!
Old January 9th, 2008, 11:50 PM
pendy's Avatar
pendy
jim pendleton
89'd90
This is how I do it. Hydraulic hose to the steel line and a Racor
JP
Name:	2nd disc 067.JPG
Old January 9th, 2008, 11:59 PM
cbass's Avatar
cbass
Bradlee Duncan
So that's your main filter then isn't it pendy? I know Jetta TDI's have a fuel return line going back to the main filter to dump the excess fuel. Does this engine not require that? Or does it return somewhere closer to the injection pump?
Very clean install BTW
Old January 10th, 2008, 12:50 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Yeah main. Returns to tank by design. Thanks
Old January 10th, 2008, 08:14 AM
ECR's Avatar
ECR
JP
Thanks cool, but it wouldn't last one New England winter in that location.
The factory Tdis had a filter in that location and on the "grey market" imports we work on and you wouldn't believe how often we have to change the stuff back there from dirt, snow, ice and salt eating it.
We use the factory filter in the factory fender mount location. Racors do filter better, used to use them on boats.
Email:
Old January 10th, 2008, 09:22 AM
And the Racor's have the option of adding/replacing the see through bowl with a bowl that has an integrated heating element for extreme cold weather!
Pendy installed mine and no issues so far, plus it's easy to get to. I understand Mikes concern as well, however not an issue in North Carolina. No rust from the hydraulic lines that Pendy installed. Also, Pendy installed with it the factory TDI fuel filter in the factory location under the wing, which now operates as a secondary, since my Racor replaceable filter is 60 micron. I can handle crap fuel in this setup.
I'll have to consider what can be done to the Racor mount to prevent rust, although it is made of aluminum, the filter canister gets change every season as part of regular maintenance, and the bowl is lexan, so it won't rust.
Old January 10th, 2008, 09:28 AM
So the stock lift pump has no problem pulling fuel through the extra Racor - or do you have to upgrade or something. I thought the lift pumps were sensitive to extra loads.
Old January 10th, 2008, 11:25 AM
I'm not perceiving any with the stock 2.8 lift pump.
Old January 10th, 2008, 12:12 PM
cbass's Avatar
cbass
Bradlee Duncan
How does the 2.8 work, is there a lift pump in the tank as well as the injection pump pulling fuel? Because if that's the case, then I wouldn't think there would be a problem with a slightly restricted flow in most applications. One option for a filter might be a Stanadyne option too, they make some big ones that are very high flow
diesel, fuel
Diesel Fuel Filter/Primer Michael Defender Technical Discussions 16 August 15th, 2006 12:45 PM
Replacing Fuel Filter...Should be easy right? Antonios Defender Technical Discussions 5 January 5th, 2006 09:38 AM
Fuel Filter milli Defender Technical Discussions 3 January 21st, 2005 10:46 AM
