Injectors Leaking - Defender Source
Old March 6th, 2011, 01:33 PM
dimcon
Chris Goldie
94 D90
Injectors Leaking
Should the injectors on a 200tdi have o-rings. There is a grove about an inch up from the nozzle. I started the engine for the first time today and on two injectors fuel was spraying from around the injector. I put new copper washer in it when I cleaned the injectors some time ago and I don't remember any o-rings before.
Old March 6th, 2011, 02:41 PM
TS888's Avatar
TS888
Tony Sims
1984 110
No o-rings per the parts manual.
Tony
1984 110 "Smokey" (sold)
Old March 6th, 2011, 03:18 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
No, no O rings. just the copper washer. which can be a royal PITA to get to seal properly.
Best bet is to stick the new seal to the injector with a little bit of grease, then gently lower it down into the head.
Trouble is there's no real way of telling whether it's sealed/seated correctly until you start the engine.
Old March 6th, 2011, 03:25 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Also make sure an old copper washer is still not down in the hole. Had a head redone and a injector pulled which was frozen in place. The engine shop left the old washer which place - it also needed persuasion.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old March 6th, 2011, 08:42 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Those can be such a pain, especially in #4. Did you replace the washers with the type that can be mashed or a flat just a flat washer?
Land Rover 110
Old March 6th, 2011, 08:55 PM
dimcon
Chris Goldie
94 D90
I replaced with the flat ones. I think I have some crush type in the gasket set so I'll try those. The diagram in Microcat shows both, is it both or just one of either? Also I noticed some carbon buildup where the washer sits in the heads so I am going to figure a way to remove that as well.
Old March 7th, 2011, 06:05 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Just one. Has a indented ring stamped in it.
Chris Hinkle
leaking diesel injectors seaswood Defender Technical Discussions 5 July 18th, 2008 07:49 PM
Fox shocks leaking... AggieD90 Defender Technical Discussions 9 March 19th, 2006 01:32 PM
Leaking A/C Ragland Defender Technical Discussions 3 May 24th, 2004 10:40 AM
Leaking... mattwhite Defender Technical Discussions 2 March 29th, 2004 09:53 AM
intake manifold leaking JRowe Defender Technical Discussions 8 February 9th, 2004 05:02 PM
