Injector washers 200/300tdi? - Defender Source
Old April 26th, 2012, 09:18 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I tried washers from the local injector shop, still had a leak, so I went with the real McCoy from Eric at AB.
My question is, which way do they go? ridge down towards the block(left pic) or ridge up towards the injector(right pic)?
Old April 26th, 2012, 09:46 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
washers
does not matter which way they go.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 26th, 2012, 09:56 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
You would think, just because one side is so different than the other
Old April 26th, 2012, 10:00 AM
roverman2010
1985 LR 90 200Tdi
washers
To please your mind put half one way and the other half the other, at least 50% would be correct.
Really does not matter
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old April 26th, 2012, 10:11 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Less than a month ago I changed out mine. I found that in the factory installed washers, the ridges were all faced down. Put a dab of grease on them to hold them to the injector.
Don't know that it matters. Be sure the seat on the head is carbon free, shinny metal all the way around.
Old April 26th, 2012, 10:23 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Sorry, read that post like it was a question, I'm a bit out of it this AM
Old April 26th, 2012, 11:12 AM
I haven't seen those washers without the rubber inner rim before.
300tdi, tdi
new or refurbed 200/300tdi starter Naplm00 Wanted 5 November 7th, 2011 12:43 PM
200/300TDI 3-bolt Bosch Starter. ajh Wanted 0 July 8th, 2010 11:29 AM
Fuel filter housing 200/300Tdi J4hand Defender Technical Discussions 0 April 15th, 2008 02:09 PM
