Injector return line leak no more - Defender Source
Old August 24th, 2013, 11:48 PM
BlackField's Avatar
BlackField
Oscar
D110
My leaky injector return lines have been a constant annoyance on an otherwise awesome truck.
I tried loctite, it didn't work but I think its because I wasn't able to adequately clean, degrease them. So I decided to safety wire them.
I bought a safety wire drill guide and hooked up the ole Dremel press and three 1/16 titanium bits later I surrendered. I took the Banjo bolts to a local machinist and he said those were the toughest bolts he ever drilled.
I safetied through the Banjo and tied it off to the injector body. I probably should of used some for of anti contact (spaghetti) tubes around it but I didn't have any handy.
Drove it around all day today and they are still snug as a bug. Hopefully they stay that way...forever.
ID:	78253   Click image for larger version
ID:	78255   Click image for larger version
high/low pressure oil line leak ? aosias Defender Technical Discussions 3 June 8th, 2012 09:17 PM
Hard Brake line leak ollieskins Defender Technical Discussions 10 May 15th, 2011 10:51 PM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
Drive line problems HELP D90user Defender Technical Discussions 4 February 17th, 2005 10:19 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
