Injector Replace / Rebuild / Nozzle Replace - Defender Source
Old April 28th, 2015, 10:08 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
My 19J which has 82K miles is ready for some preventive maint since it's new to me...what is the consensus for injectors...do most replace or have them rebuilt...and can the nozzle just be replaced or just replace the whole thing or just rebuild...I know new ones are about $50 each...
as a side note, does anyone have a good diagram of the whole fuel system for a 19J...the whole diesel thing is new to me and I see 5 or so pipes coming in / out of the fuel filter and I know there is a pump and then the other main fuel device....which has a small leak which I assume prob just needs some gaskets replaced...
The Fuel tank seems to be pressurized (not a lot) so there is something going on...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old April 28th, 2015, 10:20 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
any good?
ID:	119417   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 28th, 2015, 10:42 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
That helps...any chance you have the engine connections or pump...
Old April 28th, 2015, 10:45 PM
roverman2010
1985 LR 90 200Tdi
I do but the clue is in the pictures, hint: the link
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old April 29th, 2015, 01:28 AM
Ignotus
gene
1960 109, w/200TDI
Here, you need this; http://www.retroanaconda.com/landrov...TD_p17-167.pdf
Do yourself a favor and print out pages 105 to 151, put em in a 3 ring binder and make a copy of what ever you are going to work on that day and take it out to the vehicle to get greasy.
Generally you can take the injectors to a diesel shop and get them tested for free. Timing is everything on these motors. The injectors open at around 1900psi so don't just take them off and test em with the engine cranking.
Gene
1960 109
1960 88 Ignotus
Blog;
Old April 29th, 2015, 01:34 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
NEVER let the injector spray hit your skin, the injectors put out so much pressure in the spray the diesel will penetrate you and you most likely will die of blood poisoning.
Old April 29th, 2015, 12:24 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Most likely...lol...If its not definitive some idiot will try it just for the hell of it...
Old April 29th, 2015, 08:04 PM
seaswood
Diesel
Shop Manual
Shop manual has good information on all the Diesel engines.
Old April 29th, 2015, 08:29 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Most things I have read regarding the subject says, yes it will kill you.
But then there's always that rare someone who beats the odds.
ac, rebuild
washer jet front nozzle LR034309 Ben01 Wanted 5 February 4th, 2015 06:44 AM
rear nozzle question.... SOLVED NEVER MIND!! kevincdoyle Defender Technical Discussions 0 January 25th, 2014 08:24 PM
200tdi injectors nozzle CDNRover Wanted 6 August 16th, 2013 03:23 PM
Washer nozzle 97 d90 st mountaintek Defender Technical Discussions 3 December 18th, 2008 05:20 PM
Engine rebuild/replace advise needed. cgalpin Defender Technical Discussions 104 May 24th, 2007 09:14 AM
