Injection Pump leak - Defender Source
Old February 16th, 2016, 06:44 PM
bstauffer
Ben Stauffer
87 110 pickup
Injection Pump leak
Hello everyone, this is my first post on d90. I currently daily drive my dad's 87 110 ex mod with the typical 2.5 na. I try to keep up with problems as they occur and I like to learn to fix them on my own. I recently noticed a fuel leak coming from the hose entering the top section of the injection pump that is closest to the fan. Fuel was puddled on top of the nut that the hose goes into. I am curious as to how I would fix this? Or is it not that big of a deal? Thanks.
Old February 16th, 2016, 06:46 PM
bstauffer
Ben Stauffer
87 110 pickup
Old February 16th, 2016, 06:51 PM
Is the hose cracked? Did you try tightening the nut?
Old February 16th, 2016, 06:54 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
The dreaded Plastic hose leak.
If tightening the fitting fails, then you need to replace the line.
Remember tight is tight and too tight is bad, so don't break anything.
RDavisinVA
Old February 16th, 2016, 07:13 PM
Naplm00
Matthew
I ended up replacing all my plastic fuel line with more...plastic fuel line. The stuff sucks but will last forever.
in hindsight i wish i went with clear urethane fuel line...like the blue parts unlimited stuff but clear
Try tightening the flare nut, if not it prob leaking at the hose to metal fitting area...its just kinda jammed on there
Diesel Injection Pump - ERC6761 - Small Parts - Leak 2.5NA xjahx Defender Technical Discussions 7 August 22nd, 2014 10:37 PM
Tdi Injection Pump Leak Wolf Fabrication Defender Technical Discussions 18 January 2nd, 2012 03:34 PM
Defender 200Tdi injection pump ... Retrofit Defender Technical Discussions 2 March 9th, 2010 10:11 AM
200 Tdi injection pump removal ... Retrofit Defender Technical Discussions 3 October 28th, 2009 01:29 PM
harness on 300 tdi injection pump Abrooks Defender Technical Discussions 5 February 22nd, 2009 12:27 PM
