Ingition won't stay in position II very well - Defender Source
Old January 28th, 2016, 09:13 PM
signalMTB's Avatar
signalMTB
Rusty
'97 NAS D90 / '94 RRC / '05 L322
1994 RRC, key goes into ignition and turns fine, but doesn't stay in the position II very well. So when you start it, it wants to turn back off into the first position and therefore turns off. You have to start it and sort of hold it for a second to get it to stay. Anyone ever had this issue?
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
many others that have sold
Instagram: @SecondDailyClassics
Old January 28th, 2016, 09:40 PM
Does the '94 RRC use the same ignition switch #PRC8230 that the Defender does? If so...that's your ticking time bomb. I give it ~24 hours until total failure. Maybe less (my last one from symptom to failure was maybe 3 hours).
Then I was forced to do this:
http://www.defendersource.com/forum/...tml#post642200
And have tidied up the wiring and connectors, and been on a push-button start ever since....
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
I had the same issue in my 1994 DEF 90. I replaced the entire ignition lock and solved the problem. My guess is over the years it wears down and won't stay in II/lock.
Old January 29th, 2016, 09:47 AM
http://www.defendersource.com/forum/...uck-26677.html
Old January 29th, 2016, 11:05 AM
signalMTB's Avatar
signalMTB
Rusty
OEM part# for the 94 ignition switch is NTC9588. I'd just like to get it to a point where it stays in posII, don't really care if it's with a key or not as I never leave it parked somewhere that it might get stolen. They don't make the part anymore, no where to find it except for someone parting one out, and chances are I'll have the same problem with an old used one.
I like the push button idea...PM me with what you bought if you can
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
Old January 29th, 2016, 11:21 AM
From what I see, you actually want STC932, which is the actual switch and what should contain the detent springs to hold the key in each position.
HELP! Key won't turn past 1st position svxaddict Defender Technical Discussions 8 June 25th, 2014 02:44 PM
Door won't stay unlocked. Paul K Defender Technical Discussions 4 December 26th, 2013 07:29 PM
Ignition Switch Will Not Stay in Position II Jon_Winningham Defender Technical Discussions 7 March 11th, 2012 10:57 PM
95 ST very 4.6 very modded anthony For Sale - Vehicles 12 November 1st, 2010 01:22 AM
Won't stay long on youtube, check it now JFD Misc. Chit-Chat 5 March 10th, 2010 04:56 PM
