Info on swappability between a d1 and 90 - Defender Source
Old April 24th, 2013, 03:26 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Would a 3" lift rte and drive shafts, axle shafts swap to a 97 d90?
Old April 24th, 2013, 03:29 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Lift should work. Rear Drive shaft wont, not sure about the front. Axle shafts should be the same.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old April 24th, 2013, 03:31 PM
Only the rear drive shaft will not fit. Everything else will fit.
Old April 24th, 2013, 03:32 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Front DS will work.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 24th, 2013, 03:35 PM
The springs will "fit", but the amounts of lift will be quite different.
Old April 24th, 2013, 03:36 PM
Agreed. Its exactly what I've done in my D1-D90 build.
Old April 24th, 2013, 03:41 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
So the springs are not the same ones that they use on a d90 lift or are they the same just the ride height will differ from the d1.
Old April 24th, 2013, 03:48 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
Same springs. You will get more lift out of it on a 90 due to weight.
1995 Defender ST
1996 Discovery SE7
Old April 24th, 2013, 05:30 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Great. Will the panhard rid work?
Old April 24th, 2013, 05:44 PM
Yup.
Old April 24th, 2013, 06:18 PM
The problem is it will not lift evenly. 90s are evenly weighted front and rear. Discos are heavier in the back. The stock springs on a Disco are much lighter than on a 90.
Old April 24th, 2013, 08:28 PM
ini88's Avatar
ini88
Daniel Marcello
He is looking if they swap over and they will.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 24th, 2013, 09:21 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
So the truck won't sit even
But they are the same springs you get with the d90 lift? Is it because the d1 will have "worn them out"?
Just checked rte website and shows same part number for both 90 and d1 for the springs <shrug>
D1 axles in older D90 jafir Defender Technical Discussions 49 May 12th, 2013 11:23 AM
Donor 97 D1 swap to 94 D90... Kneel Defender Technical Discussions 2 September 9th, 2010 02:07 PM
5 15" 90 rrc d1 110 MACH 5 WHEELS BLACK willtillery For Sale - Parts 6 May 4th, 2010 02:41 PM
Adding ABS to NAS Defender Jon_Winningham Defender Technical Discussions 31 October 13th, 2009 09:32 PM
SLICKROCK fab D1 slimline front bumper mightymg For Sale - Parts 0 September 20th, 2009 11:20 PM
