Info on rear brakes - Defender Source
Old July 17th, 2014, 05:15 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Changing calipers and rotors on NAS 90.
Any recommendations?? rock auto has calipers for significantly less..... otherwise was just going to order from Trevor which I assume are likely Proline.
Also, correct me if I'm wrong, front vented and rear solid?
thanks for any help
Old July 17th, 2014, 05:25 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Trevor likely does not sell Proline. Yes vented front, rear solid.
Old July 17th, 2014, 05:40 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Right. Some aftermarket brand
Old July 17th, 2014, 06:00 PM
Rebuild the calipers you have. I have had fine luck with aftermarket rotors but terrible luck with aftermarket pads.
Old July 17th, 2014, 06:01 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
They appear to be in pretty bad shape, piston looks permanent in there..... inner pad was soaked in grease
and seems rebuild kit $25, new calipers $60-100
not huge difference
Old July 17th, 2014, 06:18 PM
When I checked a couple of weeks ago a Genuine rebuild kit was on back-order for a few weeks. They might be available now. That is for the kit with new pistons.
Old July 17th, 2014, 06:24 PM
The Dro
Dro
1988 Ninety
Check with Will Tillery. He had a D brake sale a few weeks ago on dweb
------ Follow up post added July 17th, 2014 06:33 PM ------
Found it.... it was only for the front. Doesn't harm to ask Will if he can get the rear.
http://www.discoweb.org/forums/showthread.php?t=88533
Old July 17th, 2014, 07:55 PM
Go with oem branded calipers. Or a stainless piston rebuild.
brake
Formula R1X Disc Brakes - Mountain Bike Brakes bjf The Flea Market 4 May 14th, 2012 10:07 AM
Disco disc brakes on Salisbury rear end Chris Velardi Defender Technical Discussions 10 November 16th, 2010 04:07 PM
Rear brakes(?) squeak under load kolvedic Defender Technical Discussions 3 June 25th, 2007 03:17 PM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
Need rear brakes...DIY?? P1CR Defender Technical Discussions 17 March 6th, 2004 03:46 AM
