Info on part time 4Cyl from D-90 V8? - Defender Source
Old April 25th, 2006, 12:50 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Just curious if anyone has researched this possibility for saving fuel where you would "turn off" half the cylinders when you don't need power? I would guess you would need to create your own fuel injection controller (something like Mega Squirt)...anyone thought at all about this?
George
Old April 25th, 2006, 01:09 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Unfortunately, it's basically going to give you no benefit with the valvetrain design on most engines not designed for that system. Since the valvetrain will still be functioning normally, you will have all of the compression drag in the cylinders that are without fuel. On all the other Displacement On Demand engines out there, they use different methods to force open all of the valves in the cylinders that are shut off, and this eliminates almost all of that drag. The end result will most likely be too little power to even maintain speed, my guess that you would see 50hp or less total output from the engine if you're lucky.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 25th, 2006, 01:11 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Caddy tried that a long time ago didn't work then.
Old April 25th, 2006, 01:13 PM
Hans's Avatar
Hans
Hans Haase
Yep, the 8-6-4 Caddy is considered one of the worst engines ever pawned off on the public.
-Hans
My oil line fix
Old April 25th, 2006, 06:42 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Hans let us not forget the dreaded 350 diesel.she was a gem as well
Old April 25th, 2006, 08:13 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I was building onto an Oldsmobile dealership the first winter after those 350 diesels came out. Even in the mild Tulsa winters they were hauling in the dead ones as fast as the tow trucks could pick 'em up.
Didn't the 8/6/4 Cadillac come out at the same time?
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old April 25th, 2006, 09:50 PM
Hans's Avatar
Hans
Hans Haase
Never dealt with the 350 Diesels. The 8-6-4 was 1983-1984 I think.
-Hans
My oil line fix
Old April 26th, 2006, 09:05 AM
Eric_S
Eric
'97 D-90 ST #1507
While the Olds diesel engines were a huge bust. The blocks are very strong and are sought after for building gas race engines. They're known as DX-350 block in the Oldsmobile community. If you couldn't tell my other car is an Oldsmobile.
90, d-90, part, v8
console fuse cover part on 1997 d 90 Wayne Wanted 0 November 10th, 2008 04:22 PM
FS Used 1997 NAS 90 V8 Y pipe, Genuine ECR For Sale - Parts 1 October 2nd, 2008 07:59 AM
Need odd part number 1984 Carbed V8 water pump evilfij Defender Technical Discussions 1 May 24th, 2007 10:17 AM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
Time Mike Hippert Support & Suggestions 3 October 1st, 2003 09:30 PM
