info about PTO? - Defender Source
Old May 25th, 2008, 05:17 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
info about PTO?
can anyone direct me to more info about using the power take off feature of our d-90s? what's behind the PTO plate and how does one hook up to it? is it a keyed shaft and can you run the truck with the plate removed?
thanks
George
Old May 25th, 2008, 08:21 PM
Captain Spalding's Avatar
Captain Spalding
Captain Spalding
George, have a look here. Let me know what you make of it.
Old May 25th, 2008, 11:46 PM
Gkase's Avatar
Gkase
George Kase
Well Capn...you've always got some inside info and its much appreciated...I'm toying with ways to add a battery powered motor to our trucks to add a PHEV capability for additional cheap mileage...I thought to find out what's up with the PTO access...
thanks...that's way more than I've seen anywhere else...
Old May 26th, 2008, 02:09 AM
Captain Spalding
Captain Spalding
What a delightfully insane idea! Something tells me in the end it won't be cheap. I'm interested to know the cost to benefit ratio - how many miles will you have to drive it before the fuel savings offset the PHEV mods. I'll watch with eager anticipation to see what you come up with.
I've been toying with the idea of doing an electric conversion on my other car, a 1973 VW Thing. The Thing, having so few electrical accessories, and conversion parts being readily accessible, is a good candidate.
[Edit] Now that I've had time to think about it, my first reaction was much to flippant and dismissive. Please elaborate on your idea. Do you intend that the electric motor supplement the gas engine? Substitute at low demand? What? This is an interesting idea.
Electric motor in the driver's side under seat box with a chain drive to a sprocket on the PTO? Or electric motor between the frame rails, with a drive shaft to the PTO? Have to make sure that all the gears in the TC are square cut, not saw cut. Don't want to be driving the car off the sloping side of a saw cut gear. Mind's starting to race. . .
Old May 26th, 2008, 10:54 AM
Gkase's Avatar
Gkase
George Kase
Ah...mad you say!!! Mwa-ha-ha-ha!
Yes, the idea is not to make a complete electric conversion. It is a much less expensive and less complicated electric assist for either taking off from a light and/or while at speed in neutral...my thoughts have been that with my commute which is about 30 miles, if I can get 20 miles of battery powered motion I will cut my fuel costs per trip by roughly 60% give or take... been thinking about this for a while. take a look at this idea which is on the verge of being released generally which might be just the way to build this thing...
http://www.poulsenhybrid.com/poulsen.html
and for info and parts try this one
www.electricmotorsport.com
try this fascinating experiment...place d-90 on flat surface...place in neutral, and grab the top of one of the road wheels and push the tire and observe how easy it is to move the whole truck...strikes me that, at speed, it wouldn't take much energy to keep the truck in motion with some electric motor assist. Now, whether that would occur at the PTO or at the wheel some how, or with some sort of "5th" wheel...not sure yet...the poulsen kit looks pretty cool...
also...take a look at this...shows that this is do-able...
http://cgi.ebay.com/ebaymotors/Dodge...spagenameZWDVW
Electric Cooling Fan 97 info needed. WHITE RHINO Defender Technical Discussions 8 January 8th, 2012 02:11 PM
Trouble with getting profile info chrisvonc Support & Suggestions 2 February 4th, 2005 07:55 PM
PTO Cover seal Doug Defender Technical Discussions 2 October 29th, 2004 09:52 PM
Maxi-Drive Hydraulic PTO Info Hans Misc. Chit-Chat 2 February 19th, 2004 06:40 AM
