Inexpensive, minor lift ideas sought.. - Defender Source
Old September 16th, 2004, 12:39 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Hello All,
A friend of mine is looking to lift his 94 D-90 (port fitted aluminum Hardtop), but he doesnt want to spend a lot of money on it. He uses the truck primarily as daily transportation, and to get around construction sites (he works in the excavation business). I have three sets of springs around, and a set of OME Shocks that he is interested in using. We have the following springs to choose from:
OME 751s 14.3 230 lbs/inch
OME 785s 17.0 200 lbs/inch
Range Rover Pink/Greens (OEM Rears) 17.2 180lbs/inch
I was considering using the Pink/Greens in the front, and the 758s in the rear, but I think he is looking for a little bit stiffer spring in the front since he does a lot of on-road mileage. I could but the 751s in the front (No winch, stock bumper) and the 758s in the rear. If I remember correctly, this should give him 1.5 maybe 2 of lift (Am I remembering this correctly?) My Question is that I remember people talking about putting the D-90s stock rear springs in the front, and using and OME spring in the rear. Anyone remember which OME spring would compliment this in the rear, and how much lift this combination would give the stock D-90? I believe the stock rear springs are 15.3 and 14.75 respectively and 240 lbs/inch (Anyone care to confirm/deny for me?)
He is looking for 1.5 to 2 of lift, nothing major and running either 285/75 or 255/85 BFG MTs. Thoughts or words of advice? Ive forgotten so much of what was forefront in my mind six years ago when I lifted my D-90. Thanx in advance..
~Scott T.
'95 D-90 ST - AA Yellow
Old September 16th, 2004, 06:59 PM
redrover
Guest
Posts: n/a
Put the 751 hd springs in front , and put a pair of 764 md in rear. The 764s only cost 150.00 . This setup will give you 1.5-2.0". You can still run the stock shocks. But off rd articulation will be limited by their travel. This setup is perfect for 285 tires. No rubbing You can install with minimal tools. You dont /dont/ dont need a spring compressor. JP
ht
Bumper Sticker Ideas chris snell Misc. Chit-Chat 46 November 18th, 2005 08:02 AM
sway bar ideas redrover Defender Technical Discussions 10 October 1st, 2004 09:56 PM
Windscreen ideas Mike Hippert Misc. Chit-Chat 40 July 9th, 2004 02:38 PM
CB mounting ideas flippedrover Defender Technical Discussions 21 March 29th, 2004 11:22 PM
D90 Starts Slowly. Any ideas? cdnpaul Defender Technical Discussions 7 October 31st, 2003 11:27 PM
» Defender Registry
BUD
BUD86
Clank
HalweJakkals
Add your Defender
