Inexpensive diesel filler? - Defender Source
Old October 24th, 2013, 08:35 PM
Axel's Avatar
Axel
jack
1987 Defender 110 5-door
One big advantage of the 200TDi motor is supposed to be that it can run well on cheap 3rd-world fuel. Since I can't find any cheap 3rd-world fuel around here, is there any way to add some cheap fuel or innocuous fluid to the over-priced diesel fuel we can get around here? I don't mean going all the way to bio-fuel or cooking grease, but can we add something inexpensive to the standard diesel & it still run without hurting the motor?
Old October 24th, 2013, 08:46 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
search for two-stroke oil as a diesel fuel additive - perfectly good solution for travel as it is available everywhere (marine outboard and motorcycle/scooter) though there are many better additives available.
Old October 24th, 2013, 10:33 PM
Axel's Avatar
Axel
jack
That's a good idea, & thanks. But here, 2-cycle oil is more expensive than diesel.
Old October 24th, 2013, 10:45 PM
Axel's Avatar
Axel
jack
Great idea - really? Or are you joking?
------ Follow up post added October 24th, 2013 09:50 PM ------
ok my bad. I'm reading about it over on thedieselstop.com forums
Old October 24th, 2013, 11:31 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Jack:
You can add used hydraulic oil as well as other used oils.
You could also check with local transmission shops and mix used ATF.
Ideally, it needs to sit for a week or so to settle out solids and then get a good filtering (multiple passes).
Your filter will clog faster with adding these used fuels, so keep a spare or 2 with you at all times.
A sedimenter will go a long way to trap water and particulate.
I had some good quality ones manufactured, so if you don't have one already, PM me for details.
I'll put the FS post up again in case you didn't see it.
RDavisinVA
Old October 25th, 2013, 07:43 AM
Axel's Avatar
Axel
jack
Thanks. Yes, I'll PM
Jack
diesel
New or Used NTC2676 Fuel Filler for Diesel 90 DBrands Wanted 3 October 15th, 2012 11:32 AM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
diesel leaking from filler cap artm Defender Technical Discussions 2 December 4th, 2004 05:59 PM
Adding a Side Tank - Alternate Filler Method JimC Misc. Chit-Chat 6 October 25th, 2004 12:29 PM
