indicators - Defender Source
Old January 28th, 2008, 06:47 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
indicators
since changing my indicators from the bumper to the side lights they flash ten to the dozen (fast). all bulbs are working, they are still the ligh bulbs, which part # bulb do i need to use, iv'e tried a few but none seem to work.
3rd low and BOOT IT
Old January 28th, 2008, 09:00 AM
Abrooks's Avatar
Abrooks
Tony Brooks
You may want to try the archives on this -- I remember it being a big topic several years ago (2000/2001?) when a lot of '94 owners started putting on after market bumpers. If I remember correctly (which is doubtful) you can get away with using the bulb and lens from a '97 -- at least that's how I seem to remember doing it. I'm sure plenty of people will chime in, though.
Old January 28th, 2008, 12:46 PM
Jimmy,
Let me know what you find out, mine does the same thing.
Old January 28th, 2008, 01:41 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Are you guys talking about moving the blinkers from the bumper to the front bezel where the parking and headlights are? Or moving them to the side light on the fender?
Moving lights from Bumper to Bezel:
I moved mine from the bumper to the front bezel and they work perfectly. I used a Series III rear brake light as the housing unit and replaced it with a double filament light for the two actions of 'blinking' and 'on' state when the headlights are turned on. You throw out the red lens and replace it with a yellow lens. fits perfect and flashes perfect.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 28th, 2008, 01:59 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
moving indicators from bumper to bezel and using one of the side/parking lights
3rd low and BOOT IT
Old January 28th, 2008, 02:11 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
We use the same things as ini88 listed above on the early 94 (white lamp base). The later 94s (black base lamp) you can use the rear amber lens from a Euro 110 and a different bulb and it plugs in and flashes right.
Something I haven't tried but should work in theory is using the new variable load flashers like is used in an LED kit. These should stabilize the flash rate as they do not look at the "load" like the factory flasher units do.
Email:
Old January 28th, 2008, 10:44 PM
Let me know how it goes Jimmy. Mine has been like that since I got it. Never annoyed me until I got the 110 (which blinks correctly). Now it drives me nuts.
Old January 28th, 2008, 11:11 PM
themaxx's Avatar
themaxx
Ade
94 ST
Pics please...
Old January 29th, 2008, 04:19 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
HI Guys if i am reading the thread right the problem is the blinkers front and rear are different wattages from the side, the side blinker is a 5watt the main blinkers front and rear are 10Watt.
You will need the replace the bulbs with 10W types to get the correct flash rate, as ECR says an LED flasher will work but care is needed as some of the poor copy led flashers I have seen will not drive more than 10watts total as LEDs are low power consumption devices.
Regards
Gren
Old January 29th, 2008, 08:45 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Originally Posted by themaxx
Pics please...
bulb on , bulb off , bulb on .
3rd low and BOOT IT
Old January 29th, 2008, 10:30 AM
themaxx's Avatar
themaxx
Ade
94 ST
Come on...I'm visual guy.
Indicators stopped working ... leastonce Defender Technical Discussions 1 November 2nd, 2009 10:25 AM
Turn indicators landrovered Defender Technical Discussions 1 August 31st, 2007 01:33 PM
HELP! Indicators, Dash, Electrical Problems minorthreat Defender Technical Discussions 3 April 11th, 2007 09:19 PM
Euro style front turn indicators boshea Defender Technical Discussions 12 September 22nd, 2005 07:56 AM
indicator's rover4x4 Defender Technical Discussions 0 October 27th, 2003 03:02 PM
