Increasing diff lock linkage throw - Defender Source
Old March 9th, 2016, 01:55 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
I've been running without diff lock linkage since the engine swap. I finally got a bent link from a board member and went to go install... Now I'm finding that my lever isn't actually unlocking the diff. The throw (to the right) does not go far enough to bring the diff lock cam back to 12'o clock / front of the vehicle.
To show the distance I need, I removed the upper linkage pin and manually engaged the cam to take it out of lock. You can see in the photo that I need another 3-4mm of throw. I have toyed with trying to hear and bend the main lever but am wary of breaking it. Am I missing an adjustment option somewhere?
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old March 9th, 2016, 06:53 PM
ontheway's Avatar
ontheway
Dave
Bump
Old March 9th, 2016, 07:12 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
No ajustments, is the nipple lever flat or kinked up as in the picture?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 9th, 2016, 09:07 PM
ontheway's Avatar
ontheway
Dave
It's kicked up as in the first photo
Old March 9th, 2016, 09:17 PM
it might help if you posted what tranny and such your running.. as it is no idea.. Disco R380 to LT230? Dunno
95' D90 - daily driver..
Old March 9th, 2016, 10:46 PM
ontheway's Avatar
ontheway
Dave
As seen in the photo its the original LT77 to LT230
Old March 10th, 2016, 05:05 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I think I have an early 77 linkage. Let me look and get back with you.
Old March 10th, 2016, 06:19 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
On mine (or it might have been an older gearbox) the "pivot" shaft is threaded, where it screws into the side of the gearbox casing, so you can adjust it. Not sure how it'll affect the throw though, as I've never needed to adjust it.
As said above, there's a couple of different arms available, one is "C" section type, and the other if flat bar with a very mild Z kink in it.
WTB diff-lock linkage ontheway Wanted 15 February 27th, 2016 10:23 AM
LT230 diff lock linkage PN? sonoronos Defender Technical Discussions 3 June 18th, 2014 04:06 PM
WTB FTC4095 diff lock linkage hoxie173 Wanted 15 December 3rd, 2013 07:42 AM
Diff Lock Linkage javelinadave Wanted 5 November 15th, 2013 10:25 PM
Need some help with my diff lock linkage bitz Defender Technical Discussions 8 April 1st, 2009 08:59 AM
