Inconsistent stumble and stall - Defender Source
Old March 17th, 2014, 09:24 AM
aosias's Avatar
aosias
Alexandra
1995 D90
1995 D90 has been stumbling a bit at low speed- pulling out of the driveway, pulling away from a stop sign. Not consistent and attributed it to driver's error.
Stalled yesterday and wouldn't start- electronics fine, starting cranking, floored it and wouldn't start but was trying- a little noise from the motor. Let it sit a few minutes. Tried again and it started when I floored it. Let it sit for a few hours and then it fired right up.
I replaced the silver relays a 3 years ago. Not too sure where to start now, thinking maybe a fuel filter- the V8 has an inline one correct?
Thoughts?
Old March 17th, 2014, 09:31 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Replace the stepper motor.
Old March 17th, 2014, 09:54 AM
Assuming you have good strong spark and all of that, check the Idle Air Control Valve (IACV) it's behind and to the left of the plenum if looking from the front of the vehicle. I just went with one that is compatible with our engines from an Astro van - $42 and free shipping with Amazon Prime.
Delphi CV10033 Idle Air Control Valve
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Old March 30th, 2014, 01:17 PM
87 D110 (Ruby)
Josh - how did you find out that part was compatible? - Assuming it is that is a saving of $130!!!
I am not sure if it would fit my 95 RRC - so that is why I ask - because i need to replace mine
Old March 30th, 2014, 01:43 PM
Josh - how did you find out that part was compatible? - Assuming it is that is a saving of $130!!! I am not sure if it would fit my 95 RRC - so that is why I ask - because i need to replace mine
It's common knowledge. Search the board and you'll find many References to Chevy astro
Old March 30th, 2014, 04:10 PM
Probably not a bad notion to replace the ignition module. A sign of failure are just the symptoms you describe. Or swap it out for the $20 GM one.
Old March 30th, 2014, 05:08 PM
87 D110 (Ruby)
Might be for your little 3.9/4.0 Defenders...but I have the 4.2 for a 95 RRC - and they are apparently "special"...which is why I wanted to see if there was some type of conversion chart - or replacement chart that lists the variants
Old March 30th, 2014, 05:10 PM
Not special.
Old March 30th, 2014, 05:43 PM
The only thing that is special about your variant of the 14cux fuel injection system is your belief that it is special.... They are all the same POS.
Old March 31st, 2014, 10:18 AM
87 D110 (Ruby)
Oh but it is special....
Old March 31st, 2014, 11:16 AM
Mine is special too! ;-)
Old March 31st, 2014, 11:36 AM
You both talk funny, so i guess that make you special.
Or at the very least foreigners.
-Jeff
there are very few people who have more than 200 years lineage in this county ... where I come from that makes everyone 'straight off the boat'
Old March 31st, 2014, 11:45 AM
is one ignition module better than another. My RRC runs well sometimes and runs like dookie other times. I have a used ignition module relocation installed from a 94. The vac advance works, ive lubed the weights and use genuine cap and rotor. A quick review of rockauto shows a few options AB has one for 72 rockauto is around 40. Im a complete cheapfuck but Id like to save a few dollars, is there any reason to buy the "lucas" module?
Old March 31st, 2014, 01:06 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
Buy the Lucas. And get a set of genuine leads to go with the cap and rotor. Between the new relo of the Lucas ign amp, gen cap/rotor, and new genuine ignition wires, my 94 classic never ran better. I tried all the hocus pocus stuff and short of changing the dizzy, once those things were changed out, it was what I should have done years ago.
3.9 stumble stall code 44 rover4x4 Defender Technical Discussions 5 April 4th, 2009 02:39 PM
