inaccurate speedometer - Defender Source
Old August 4th, 2004, 06:09 PM
artm
Arthur Maravelis
97 SW
Mine reads 5mph on the high side - at 50-85, more or less - unless my gps is wrong. Stock truck, had it for about a year and just noticed it.
Anyone with the same???
Old August 4th, 2004, 06:15 PM
My GPS and speedo are about 2 mph different no matter what the speed, the speedo matches those radar things that tell you how fast you are going. Have you put new tires on it that are about an inch taller then the stock tires? An inch would give you about 3 mph off and then the GPS to Speedo thing is another 2 mph, so that gets you to 5 mph. Just a thought.
Old August 4th, 2004, 06:24 PM
artm
Arthur Maravelis
97 SW
Stock wheels and tires. I guess the next time I'm on the dynamometer I'll see what's up.
Old August 4th, 2004, 09:28 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
mine is 10mph out at any speed checked with gps and radar thing so i just deduct 10mph
Old August 4th, 2004, 10:28 PM
mine is off by 5.
Old August 4th, 2004, 10:35 PM
KeithD
Keith Duckett
90 V8 Import
Mine seemed a bit optimistic with the 205/80 tires it came with....on a GPS it is now about right - on 285/75s!
Old August 5th, 2004, 01:05 PM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
First thing I did when I bought my GPS was check it against all of my vehicles. Turns out all of my speedos read at least five MPH on the high side as of 50 MPH.
I'm not sure if I really believe this but someone I spoke with said that speedos are designed this way. Perhaps it's to make people think they're driving faster than they really are.
Old August 5th, 2004, 07:39 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
I've heard this, too. Back in the days before Hall-effect speed sensors and digital electronics, it was very difficult to make accurate speedos. In other words, stock units had a pretty loose tolerance on them. So they were designed to read on the high side, to ensure that just about every one of them read above the true speed: in order to avoid the situation where some read slower than actual, and thus might generate unintended tickets.
I bet the average speedo is alot more accurate now, such that this much slop ain't needed, but tradition and habit keeps it the way it is.
Old August 5th, 2004, 09:31 PM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Barry, your reasoning makes more sense but I sometimes wonder if there isn't some weight to the goverment conspiracy theory.
Old August 10th, 2004, 11:21 PM
ttegt's Avatar
ttegt
Thomas Tegtmeier
1995 Defender 90
my '95 d-90 runs 5 mph slower than my gps shows as well, does this mean that the odometer is showing more miles than the truck has been driven?
Old August 10th, 2004, 11:33 PM
Replace the speedo output gear in the T-case to correct.
ac, speedo
Detach Speedometer Cable Matt Klapmust Defender Technical Discussions 2 October 2nd, 2013 01:43 PM
Speedometer not working mgrgpg Defender Technical Discussions 4 June 11th, 2009 07:27 PM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
Correcting speedometer after lift/tires Seriesman Defender Technical Discussions 16 November 24th, 2005 08:37 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
