In the field question - Defender Source
Old October 11th, 2014, 12:30 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Out in the middle of nowhere, barely cell service. Went over rr tracks while letting out clutch and heard a pop
Now 90 will only go with transfer case engaged.
Clutch and tranny seem fine but really clunking under there.
Thoughts?
Can't search because of spotty service.
Thanks Board!
Attributed to Shayne...
Old October 11th, 2014, 12:34 PM
You broke a rear driveshaft. The short one usually goes first. You can drive it home with the CDL engaged, no problem.
Originally Posted by pendy
I'm here for the D's
Old October 11th, 2014, 12:39 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I have to ask, how fast were you going?
It wasn't one of those smooth tracks but but one that jars your fillings lose wasn't it?
If it moves with transfer case engaged, I'm going to say possibly a broken axle or in that vicinity. Just guessing.
Where does the noise appear to be coming from?
Black Rhino Lives Matter
Old October 11th, 2014, 12:46 PM
kevincdoyle
Kevin C. Doyle
Awesome. Think I have a burning smell as well. Normal?
Old October 11th, 2014, 01:12 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I never consider any strong burning smell good.
What kind of smell? Fluid, electrical, material?
Old October 11th, 2014, 03:36 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I think by "drive shaft" they really mean the half shafts in the rear axle. You can pull them out, you just need to tape up the half shaft "holes" (behind your wheels) to keep dirt out until you get home.
I also think you mean to say that you have the transfer case in "diff-lock" in order to have forward motion.
Old October 11th, 2014, 05:16 PM
Yes half shaft, sorry. CDL == center diff lock.
You can typically not worry about removing them for a short distance as the breaks are pretty clean.
Old October 12th, 2014, 09:22 AM
Oil cooler lines? Just kidding
Old October 13th, 2014, 11:30 AM
kevincdoyle
Kevin C. Doyle
well, made it home, attacked by gremlins tho..
Sheesh, first long(ish) trip, about 200 miles and several gremlins popped up:
1. The lights in the dash warning panel started flashing randomly, seat belt, brake, aux lights(even tho I have none) chime etc. There seemed to be 2 loose relays under the passenger seat. 1 was hot. pushed them down and seemed to take care of issue...until I got close to house...
2. Aforementioned clutch/tran/driveshaft issue. loud pop going over teeth rattling rr tracks and shifting at same time. Dumb mistake. Now only goes forward with CDL engaged. Still making a clunking sound as I slow down with or without clutch engaged. Sounds like someone going from side to side with a pipe under there as I slow down and with no torque on drive line.
3. Annnd right when all of these guys were admiring and looking at truck, ignition switch decides to go out. no lights, no nothing unless I faced east, jiggled key and called upon the Lord of Darkness himself. Finally got key in just right spot to get it started. Had to "tug" on key while driving to keep power. Assuming this is a simple replace of ignition/key part.
Thanks for the quick replies guys!
Any thoughts, kindly let me know!
KCD
------ Follow up post added October 13th, 2014 03:33 PM ------
Smell seemed to be "fluid" in nature and really only happened if I went over 70. Clutch was full when I got home.
Old October 13th, 2014, 12:37 PM
kevincdoyle
Kevin C. Doyle
anybody have a link...
to a solution or the fix for this problem?
All British Field Meet Bellevue, WA isleofman Trips, Trails and Events 1 July 27th, 2011 10:37 AM
Land Rover event Portland, OR- All British Field Meet this weekend eric_besore Trips, Trails and Events 0 September 3rd, 2005 01:09 AM
Question Transporting a workshop manula in the field? Eric Siepmann Misc. Chit-Chat 3 December 8th, 2003 10:00 PM
