In situ gear selector housing removal - Defender Source
Old September 24th, 2011, 10:50 AM
michael67's Avatar
michael67
Michael White
110 Tdi
Hi all!
I'm tracking down a transmission fluid leak that seems to be coming from somewhere on the upper portion of the transmission. Is it possible to remove the gear selector housing on an LT77 in a 110 without dropping the transmission, i.e. just remove the shift cover and center console/cover instead?
Thanks.
Old September 24th, 2011, 01:19 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
You mean the bit on top of the main 'box that the shifter attaches to?
yes, 4 (or 6?) allen screws, or 8mm bolts, depending on age, will release the top unit.
you just need to pull up the rubber gearstick gaiter and the foam soundproof bit to get access to it.
When i was in the Army, we used to have to do this a lot, as some of the older rovers, the grub screw would come loose on the shifter resulting in a floppy non-engaging gear stick.
Old September 24th, 2011, 06:05 PM
michael67's Avatar
michael67
Michael White
110 Tdi
Jamie,
I know that screw - it came out on mine about five miles from home . But I think what you're referring to is what the manual calls out as the gear lever housing. I'm talking about the thing that the gear lever housing sits on, that looks to bolt to the extension housing.
Old September 24th, 2011, 09:47 PM
pendy's Avatar
pendy
jim pendleton
89'd90
No you have to remove the transmission to pull the extension housing off. Not a chore to be done insitu.
legend in my own mind
Old September 25th, 2011, 12:34 AM
michael67's Avatar
michael67
Michael White
110 Tdi
Thanks!
Bearing removal on a t-case input gear TDI Guy Defender Technical Discussions 8 September 28th, 2009 07:06 AM
Gear ratios - 1995 NAS Defender? jam90 Defender Technical Discussions 3 February 19th, 2006 03:58 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
Speedo Gear Removal 48vphantom Defender Technical Discussions 2 March 27th, 2005 02:51 AM
