in need of some quick help: 200tdi engine mounts - Defender Source
Old September 5th, 2014, 07:15 AM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
Im currently in the middle of a 200tdi swap and fighting the small battles as I go. I seem to have hit an issue: The motor has what looks like 2x Left side engine mounts. A quick measure shows roughly 22" between the frame mounts and 25+" between the engine attached mounts. this seems wrong.
My assumption is I need to use the Right Hand mount off the 2.5NA (see attached image)? thanks in advance!
ID:	102193   Click image for larger version
Old September 5th, 2014, 08:13 AM
Yup you have two LH mounts.
Old September 5th, 2014, 08:16 AM
the mounts off your 2.5 should be identical to the 200 mounts. Just swap them if there is any concern.
Old September 5th, 2014, 08:18 AM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
Many thanks!
Old September 5th, 2014, 08:21 AM
anytime. Your truck will transform.Hopefully you are changing the transfercase as well ?
200tdi, engine, mount, tdi
200tdi engine mounts tomaco1 Defender Technical Discussions 3 January 23rd, 2013 08:13 AM
Need some quick confirmation of 200 tdi alternator wiring KevinNY Defender Technical Discussions 0 February 13th, 2011 02:24 PM
Need some Quick help with my Coil matthewwcarey Defender Technical Discussions 0 December 31st, 2010 10:40 AM
Tranny Mounts, 4cyl engine mounts, Tub tomaco1 Wanted 0 December 4th, 2010 12:42 PM
2.25L and 200Tdi engine mounts question Gkase Defender Technical Discussions 8 April 10th, 2009 08:53 PM
