In-line Fuel Filter Recommendation - Defender Source
Old March 6th, 2012, 06:21 PM
usadventureracing's Avatar
usadventureracing
Brett
110
Can anyone recommend an in-line fuel filter for a V8 3.5? Also assuming the filter should be installed between the pump and carb, please correct me if I am incorrect.
1983 ROW D110
1970 Series III (Parting out)
Old March 7th, 2012, 08:18 AM
LRover's Avatar
LRover
J. Michael McCaig
I just installed a universal type inline filter close to the carb in addition to the OEM filters. NAPA or most other auto parts stores carries them. The early 110 V8s also had a canister type fuel filter mounted on the right side of the frame. NAPA carries the replacement filters. The original Facet fuel pump also has a bronze type built in filter that should be cleaned periodically.
Old March 7th, 2012, 10:04 AM
usadventureracing
Brett
110
Thank you for this info. I have the old canister but was thinking I could just use an inline and nothing else. In fact when I took the old canister apart during my rebuild there was no filter in it. Looks like I was driving with no filter at all.
1983 ROW D110
Old March 7th, 2012, 11:09 AM
I bought a Jeg's one for the boat. Mine has AN fittings but they come barbed or flare. Do NOT use the glass type in line filter.
Old March 7th, 2012, 11:14 AM
usadventureracing
Brett
110
Do have part number for the jegs filter?
1983 ROW D110
fuel
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Replacing Fuel Filter...Should be easy right? Antonios Defender Technical Discussions 5 January 5th, 2006 09:38 AM
Fuel line valve cracking RickM Defender Technical Discussions 2 October 21st, 2004 11:15 PM
