In Dash Starter Button - Defender Source
Old November 4th, 2007, 09:57 PM
matthewwcarey's Avatar
matthewwcarey
Matthew Carey
95 D90 SW349
Anyone have any info on installing a dash mounted starter button? I saw one on a used 95 D90 for sale at a dealer in NJ.
Thanks Matthew
Old November 4th, 2007, 10:06 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You mean like this:
I know thats now what your after but the switch itself is not hard to install. I think I even have a nice one laying around if you get serious.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 4th, 2007, 11:36 PM
themaxx's Avatar
themaxx
Ade
94 ST
There is a write up by D Chapman on DWeb about putting one in a D1. I don't know if our Defenders and a D1 is similiar in that regards.
www.discoweb.org/forums/showthread.php?t=36683
Old November 5th, 2007, 12:34 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Funny enough, I'm using one right now, as my key-driven ignition switch kinda self destructed a couple weeks ago. It's only temporary in my case, but it works.
The wiring part is easy, as you just need to use the 4 wires that come off the back of the ignition switch. One is the power feed. One goes to the accessory portion of the wiring. One is for the Ignition power. The last one is for the starter. Optimally I would go with a 3 position rocker switch and a push button. This way you get the ability to use the accessories separately like a key would allow.
Were you looking to totally remove the key setup? Or still use the key, but have the pushbutton for the starting?
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 5th, 2007, 08:11 PM
matthewwcarey
Matthew Carey
95 D90 SW349
Starter button
Hans
Thanks for the info, the set up I saw on the 95 D90 was used in conjunction with the key ignition. The key would power the accessories and that's as far as it would go, then you would depress a start button on the dash to engage the starter.
Matthew
dash, start, starter
Starter issues on my D90 Rover- Girl Defender Technical Discussions 13 February 13th, 2010 10:59 PM
Top Dash Panel and rear windshield wiper button wanted for D90 Manimal Wanted 2 September 18th, 2008 02:17 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
1997 Dash panel - what's there? ronward Defender Technical Discussions 6 April 26th, 2004 05:47 PM
