In a pinch.....Harmonic Balancer failure? - Defender Source
Old July 15th, 2013, 01:44 PM
kite_eating_trees
Michael Morgan
1994 Defender ST
I'm seeing a tremendous amount of inbalance from the lower crankshaft pulley. I guess the harmonic balancer is failing. Some ticking noise associated with the failure. The issue is.... I can't seem to find a replacement harmonic balancer. AB and RN both said they had no replacement. Any advise on where to find one of these? Thanks, Morgan
Old July 15th, 2013, 02:29 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
1996 DI with serpentine belt?
We have a 1996 DI with serpentine belt.
Will that work?
RDavisinVA
Old July 15th, 2013, 03:28 PM
kite_eating_trees
Michael Morgan
1994 Defender ST
Not sure. Can anyone verify that a disco HB will fit?
Old July 15th, 2013, 03:38 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
No you need a front crank pulley from another V-belt 3.9. Think Range Rover Classic
Old July 15th, 2013, 04:07 PM
I have some bits left over from a v-belt 3.9 (94 D90) but I'm not exactly sure what part you need. Have a picture? Once I know what to look for I can brave the heat and go look for it.
Originally Posted by pendy
I'm here for the D's
Anyone have an alternator pulley and a harmonic balancer they can measure? Turbofan Defender Technical Discussions 0 October 21st, 2011 10:35 PM
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Rear trailing arm bushing failure sheki Defender Technical Discussions 23 July 5th, 2006 09:20 PM
Harmonic Balancer woldd90 Defender Technical Discussions 2 April 3rd, 2006 07:11 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
