Importing a 110 - help! - Page 2 - Defender Source
Old May 3rd, 2016, 04:59 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Depends on if the factory put them there or not.
Most trucks built for the MOD have no chassis VIN stampings.
Ah good point. I was assuming normal run of the mill 90/110.
Old May 3rd, 2016, 05:20 PM
greenmountainrover's Avatar
greenmountainrover
Derek Chace
84 Lightweight FFR
but they do have the seat box ID plate that normal ones dont have
Green Mountain Rovers your Defender/Series sales and importation specialist.
802-655-4874
Old May 3rd, 2016, 05:22 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
The best are the 'My 'friend' just imported a defender from Spain ... and they are wondering why it has leaf springs'
damn santanas!
Old May 3rd, 2016, 05:37 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Also, seems like somebody posted something to the effect that LHD conversions done overseas prior to importing can also create an importability issue with the brake booster vin id. Anyone?
Old May 3rd, 2016, 05:47 PM
You are not allowed to import a truck that has had the drive side swapped.
Old May 3rd, 2016, 05:58 PM
AdamSanta85
91' D90 200TDI
Unless the truck is basically stock and contains all original identification markings. The answer is no.
Old May 3rd, 2016, 06:16 PM
cowboy
steven
Not sure I catch your drift - I wasn't intending to ask the question that you seem to be answering...
Anyway, here's the post that I was referring to:
The reason left hand drive conversions are not admissible here is because simply moving the brake booster with VIN plate from one side of the truck to the other is considered VIN tampering by DOT, no other reason.
Old May 3rd, 2016, 06:27 PM
Their logic is impeccable.
Converting a RHD car to LHD is dangerous.
Ergo, proof that LHD cars are dangerous and we should all convert to RHD cars as if we'd never left the imperial tyranny of the British Empire.
Old May 3rd, 2016, 06:48 PM
changing a chassis is considered vin tampering
moving the brake booster with plate affixed is vin tampering
removing the vin plate from the booster bracket, painting the bracket, and re-attaching with new rivets is also vin tampering per dot.
on arrival the vin will be decoded
that vehicle must be what is before the officer
VIN's indicate engine type, body type, which transmission, as well as handing
Old May 3rd, 2016, 06:57 PM
Willh's Avatar
Willh
Will Hedrick
Use to own NAS #96, #1778, & #1008
fwiw many trucks don't have a vin in either place.
Unfortunately, the above statements are not accurate.
Through my research I have substantiated that every chassis that left the factory had, at a minimum, a 6-digit chassis identifier (i.e., these also constitute the last 6-digits of a full VIN). And, note that I used the word "chassis". Even CKD vehicles intended for Complete Knock Down production in other markets had factory assigned chassis identifiers. There are also other identifying characters on the chassis, such as the chassis batch number.
Please feel free to visit my website at:
Willh is the F'n man! Defender of the Defenders! - Overlander
Old May 3rd, 2016, 07:08 PM
Originally Posted by Willh View Post
Unfortunately, the above statements are not accurate. Through my research I have substantiated that every chassis that left the factory had, at a minimum, a 6-digit chassis identifier (i.e., these also constitute the last 6-digits of a full VIN).
When it come to Land Rover I always hesitate to say "every" or "all" unless I'm talking about a leak of some sort.
Was that chassis fact provided by Land Rover - i.e. their expectation was that every chassis would have a number, regardless of whether it was for MOD, private, CKD, municipal, etc.?
Old May 3rd, 2016, 07:18 PM
rovertrader's Avatar
rovertrader
Dale
I have had 7 or 8 MODs and all had VIN plates as well as chassis VIN.
I have had a CKD kit, and it too had identifiers.
Derek is also correct in that the contract info is listed on a seperate plate, but I always figured LR kept tabs of VINs used to fulfill said contracts.
Old May 3rd, 2016, 07:24 PM
globallandrovers's Avatar
globallandrovers
Julian Kotting
1999 P38 DT, 1997 LHD 110 CSW
Location: Hertford UK, Wilmington, NC, Austin, TX and OH
Originally Posted by dieseloneten View Post
Hey all - urgent query
A buddy is importing an early 110 into the US. The car is original spec and meets Customs requirements. It's on the boat to the East Coast right now.
However he has just run across a problem. He has been told the VIN number needs to be in TWO places on the truck - 1. On the frame and 2. On the brake booster
He only has the VIN in one place - on the frame. So he is now panicking thinking the vehicle will be impounded or worse.
He has been told there is a company in the UK who can provide a plate that will show the VIN number in the correct place. Does anyone know of such a company?
Or is this panic over nothing and will a VIN on the frame be enough?
Sorry - weird question I know
D110
If he can prove that he is the owner Land Rover will make you new Vin plates Genuine, last time I had this done it cost about 120.00
Land Rover Defender Specialist. - We ship worldwide.
We are a specialist in TDI re-power conversions, and Crate 'turn key' Land Rover TDI and TD5 engines and Transmissions.
Old May 3rd, 2016, 09:12 PM
Willh's Avatar
Willh
Will Hedrick
Old May 3rd, 2016, 10:05 PM
Wondering if I had lost it, I walked up to look at the 4 military trucks here. Two have vin stamped chassis. 1 does not, that I can find, the chassis is stripped bare, paint torched off etc. 4th has an arb bumper covering that part of the frame.
chassis with no visible no's is a soft top tithonus
Old May 4th, 2016, 09:48 AM
Willh's Avatar
Willh
Will Hedrick
I stand by my statement.
Old May 4th, 2016, 01:50 PM
Willh's Avatar
Willh
Will Hedrick
To clarify, are you referring to chassis' that left the factory as an assembled truck? You have CKD in there.
-Jeff
Both the chassis of factory assembled vehicles and the chassis of complete knock down (CKD) vehicles have factory assigned chassis identifiers (i.e., 6-digit serial numbers). Keep in mind though, not all vehicles bear a full 17-digit vehicle identification number (VIN).
110, import
Need help importing Rover from Bahrain red64chevelle Misc. Chit-Chat 4 April 3rd, 2011 11:26 PM
Need help importing photos Lindy Support & Suggestions 10 April 30th, 2009 07:19 PM
UK Citizen importing D-110 ....US rules Cyborg Defender Technical Discussions 11 March 2nd, 2007 05:46 PM
Importing 110 TwisteD90 Misc. Chit-Chat 7 December 21st, 2006 04:05 PM
Importing a 110 to the States mfreeman17 Misc. Chit-Chat 18 April 14th, 2005 02:02 PM
