Implications of going from a NAS roll cage to Full Body Cage. - Defender Source
Old June 24th, 2013, 02:56 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'm considering going from a NAS "half cage" to a fully body cage on my NAS D90 (SW). Any special considerations I should keep in mind? I assume I need a new roof? I assume the front and internal (behind seats) mounts can be reused?
Old June 24th, 2013, 03:05 PM
Look up Chris Von C's thread from a few years back. Probably just about all of the information you'll be looking for is in there.
Old June 24th, 2013, 03:06 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Perfect. Thanks!
Old June 24th, 2013, 03:15 PM
Other than cutting new holes in the tub, you're going to have two old holes on each side of the roof that aren't used any more. The inside hoop is soft top only and unless something has changed, the full external cage doesn't bolt through the top like the half cage.
Old June 24th, 2013, 05:39 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
I did that on my truck when it was a 90 and I cut the mounting plates off of the half cage since someone else who bought the front of the cage was not using the side bars and used them with a small piece of pipe as an extra mounting point for the external cage. Worked great and no holes exposed on the top.
Old June 24th, 2013, 08:55 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Chris' thread didn't actually feature a write up. Only promises of one. I do recall Jim having posting a proper write up when installing his 110 cage. It should be pretty similar to that, right?
Old June 24th, 2013, 09:08 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Great tag line! At the bottom of your post.
Old June 24th, 2013, 09:18 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Have you taken a look at Safety Devices web page? http://www.safetydevices.com/expedit...hout+bulkhead|
Old June 24th, 2013, 10:00 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Yes but I can't quite figure out why 7 different options are needed for a D90. Actually I'm just lazy and I need someone to tell me which out of the 7 options is the best.
Old June 24th, 2013, 11:15 PM
bjf's Avatar
bjf
barry f
94 ST #395
Can I ask why you want to do it?
Old June 25th, 2013, 12:12 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
No you can't.
Not saying I want to, just curious to see what it would involve. A full cage would be nice to prevent the tin foil they call body panels from buckling when on the trail. I've already got a few dents. Also if you roll it doesn't squash gear or passengers which would be nice. The external cage is nice as it leaves more room inside and the bars on the outside protect from body damage and scratches. After looking into it though, it doesn't seem worth the cost and effort considering I already have a cage that protects the passenger compartment. If I had no cage to begin with it would probably be more worthwhile.
Old June 25th, 2013, 12:14 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks. Yes, upon reading up closer the difference between them are apparent.
Why the preference for the internal one? Pretty claustrophobic, no?
The one you asked about
Full External:
http://www.safetydevices.com/expedit...3-present/302/
The one I like
Full Internal:
http://www.safetydevices.com/expedit...3-present/801/
-Jeff
Old June 25th, 2013, 08:47 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Ah, it's an aesthetic consideration.
Old June 25th, 2013, 09:03 AM
I don't know. The first time you tape a van side or your roof with a tree, you might reconsider.
Old June 25th, 2013, 09:47 AM
External will be my preference. It's harder to do but I think its worth it to protect body work as well as brain cells
Old June 25th, 2013, 09:51 AM
jcb-memphis's Avatar
jcb-memphis
Jeff B.
They went external for 110 nas trucks probably for space and perhaps injury prevention inside....just a thought. Also has a very neat "look" to it..unique. Probably costs 1-2mpg though.
LR History:
110 hybrid (from a 90) NAS Defender "Oates" #1597
2002 D2 SE "Very Disco" (sold)
1993 RRC LWB "The Beast" (sold)
Old June 25th, 2013, 01:10 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
If you reuse the roof tabs from the current SW cage and leave the internal hoop, connect them to the full exo-cage you have something like the NAS 110 set up with full external cage and internal hoop behind the front seats. You keep your roof this way too.
This would assume no conflict with the body mounts behind the front doors. I had a big concern with my kids in the back seats in the SW due to the lack of protection in the back half of the truck. Full cage would help.
A couple of posts from CVC on his upgrade:
http://www.defendersource.com/forum/...highlight=cage
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old June 25th, 2013, 07:01 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I agree. The external is nice as it essentially acts as tree branch sliders all around the vehicle.
Old June 25th, 2013, 07:04 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Great idea! How much fabricating do you think would be necessary for something like this?
Old June 25th, 2013, 08:26 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
For a competent fabricator, not much at all.
NAS Roll cage components Method PHX For Sale - Parts 7 April 10th, 2009 01:34 PM
Safety Devices Full Extenal Roll Cage chrisvonc Defender Technical Discussions 36 April 26th, 2006 10:01 PM
Trade roll cage? bstraw Wanted 1 March 28th, 2006 05:44 AM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
NAS roll cage archoid2 Wanted 6 October 31st, 2003 07:28 PM
