Imperial Fan Clutch replacement - Defender Source
Old May 31st, 2006, 11:44 AM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
I'm not sure which Rover a 215157 Imperial Fan Clutch fits, but it's not the 94-95 D90. I just picked one up from Advance Auto, with the Help! kit RoverChic mentioned. I should have brought the stock clutch to compare at the store, but I was on my bike. First issue I noticed was the shaft is about an inch longer than the stock one, and I didn't think the fan would clear the radiator. But then it didn't matter because the water pump threads are too big.
Perhaps this works for the 97 D90s? I dunno. I'd love to find an inexpensive replacement for the stock viscous fan clutch, because then I'd stick with the mechanical instead of switching to the electric fans.
Originally Posted by Mike Hippert
I could run circles around Dave Souzas 90
Old June 1st, 2006, 02:33 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
02 D2, 13 E350 AMG, 11 Ford F350
Oh I am soo sorry Souza! It is for the 4.0L.....If you re-read the the thread I did post the NAPA Part number which I know for sure works on a 3.9L truck. It is 84.xx plus tax. I am sorry again...Ugg!! I did you a dis-service by posting wrong info!
I bought the diamonds myself so I would not have to say thank you to anyone.
Old June 2nd, 2006, 10:01 AM
souza's Avatar
souza
Dave Souza
Don't sweat it roverchic, it's good to hash it all out so everyone knows. I checked my local NAPA and the have that number for the price you mentioned, so I think I'm going to try that one out later today.
So all is well!
Old September 17th, 2006, 08:19 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Hi all. I am quite confused. I bought the NAPA part referenced and it does not fit. The nut is considerably larger than the 32 mm one on the original (1995 ST, 3.9L) but otherwise apears similar, if not the same. It is definetely the NAPA 271304. The original is marked ERC-5708 as noted in another post. Is it possible I have a different pump? Any guidance is greatly appreicated.
Oh, and it has been running in the 220 ish range (no boil-over) according to my VDO temp gauge that seems to be pretty accurate. Anyone know if that is dangerous (ie:dropped sleeve temp?)
Thanks~
Pain is weakness leaving the body
Old September 17th, 2006, 08:36 PM
souza's Avatar
souza
Dave Souza
Opps, I guess I never replied back to this thread... perhaps I started another because I'm pretty sure I posted back about this somewhere... in any case, the NAPA part didn't fit either. As far as I'm still aware, there is no replacement for the 3.9 engine, from NAPA or Imperial.
Old September 18th, 2006, 03:21 AM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
I just did mine today (well yesterday now). I went to Autozone and got one for $120. I don't know the part # but I just told them the year and model and it was the easiest install ever, just used a screwdriver and a hammer to get the nut loose.
Old September 18th, 2006, 01:53 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Damn I'm gonna try that, how big of a screwdriver do you gotta use? Does it have to be sharp? BTW you get a lifetime warranty on the autozone fan clutch so I think its worth the $120 bucks. They put a record of your purchase on a computer so no more holding on to faded receipts.
Old September 20th, 2006, 09:51 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Not meaning to bump this, but figured I would follow up with the P/N from AutoZone. THe clutch looks identical to the one that came off the d-90 (1995 3.9l V8 NAS). The Autozone part number Dennis was referring to is: 922301 and the mfg is TorqFlo, made in Germany. Anyways, perfect fit and all is well there anyways. THanks again!
Old September 21st, 2006, 05:21 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
I just used a screwdriver that was long enough to reach the nut. 6-8 inches maybe. You just have to give it a good whack. The part was the torqflo as mentioned above.
Old August 18th, 2008, 09:05 PM
Do the wrenches not work on the fan clutch? Why does everyone beat it up with a hammer? I found part number from Advance Auto Parts is Imperial 215053. Do you have to take the fan shroud off?
Old August 18th, 2008, 10:45 PM
Grover's Avatar
Grover
I just replaced my viscous fan clutch pn: ERC5708. It is much easier to remove the fan shroud when doing so. I rented tools from AutoZone to remove/install the clutch. Simple fix...
Good Luck...
Old August 19th, 2008, 11:36 PM
Damn, old thread - thought Souza was back for a minute...
Ditto on the rented tools from autozone.
ac, clutch, fan, fan clutch
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
Fan replacement davedeojay Defender Technical Discussions 10 March 23rd, 2005 02:00 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
