Impact switch - Defender Source
Old January 1st, 2004, 10:35 AM
watsonlegend
Bill
94' Defender
Impact switch
I have a 94 D-90. Is there an impact or collision switch? If so, where is it located?
Old January 1st, 2004, 03:32 PM
Its on the middle of the firewall, in the vicinity of your air intake. It's black, round, and rubber.
Old January 2nd, 2004, 12:50 PM
Mine is behind the fusebox next to all the relays. There is a little red button on it to push in when it is set off. I tested mine by banging the lower dash until it poped.
Old January 10th, 2004, 09:50 PM
watsonlegend
Bill
94' Defender
Thanks for the help Mike. On the 94 it is behind the fusebox. On the 97 it is on the firewall.
Old January 10th, 2004, 10:19 PM
i have a 95
ac, switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
